Ok guys… Why don’t my tiles update? The debug messages all look proper but nothing updates???
* WaterTempSensor
* Copyright 2018 John Intorcio
metadata {
definition (name: "DualWaterTempSensor", namespace: "JIntorcio", author: "John Intorcio") {
capability "Sensor"
attribute "laketemp", "string"
attribute "tubtemp", "string"
attribute "lakebat", "string"
attribute "tubbat", "string"
tiles(scale: 2) {
valueTile("laketemp", "device.laketemp", width: 2, height: 2) {
state("laketemp", label: '${currentValue}°') }
valueTile("tubtemp", "device.tubtemp", width: 2, height: 2) {
state("tubtemp", label: '${currentValue}°') }
valueTile("lakebat", "device.lakebat", width: 2, height: 2) {
state("lakebat", label: '${currentValue}%') }
valueTile("tubbat", "device.tubbat", width: 2, height: 2) {
state("tubbat", label: '${currentValue}%') }
def parse(String desc) {
def msg = zigbee.parse(desc)?.text
log.debug "Parsed message: $msg"
def name = ""
def name2 = ""
def value = "Null"
def value2 = "Null"
if (msg != "ping") {
//msg format is [index] hyphen [temp in F * 10] hyphen [battery level]
//Example 0-760-98 means it's a Lake temperature of 76° and battery is at 98%
//Split on hyphens
String[] Msgparts = msg.split("-")
log.debug "Msgparts: $Msgparts"
//Msgaprts is an array like [0, 760, 98]
//First value is the index: 0 --> Lake, 1 --> Hot Tub
int Index = Msgparts[0].toInteger()
//Pick the attribute for the temperature Update
if (Index == 0)
name = "laketemp"
else
if (Index == 1)
name = "tubtemp"
else
name = null
int IntVal = Msgparts[1].toInteger() // Convert to integer
value = (String)(IntVal/10) // Divide by 10 and turn back to string
// Create the temperature event
def evt1 = createEvent(name: name, value: value)
log.debug "Temp event: ${evt1?.descriptionText}"
//Pick the attribute for the battery Update
if (Index == 0)
name2 = "lakebat"
else
if (Index == 1)
name2 = "tubbat"
else
name2 = null
value2 = Msgparts[2]
// Create the battery event
def evt2 = createEvent(name: name2, value: value2)
log.debug "Battery event: ${evt2?.descriptionText}"
//Return two events
return [evt1, evt2]
