There is always added 45 or 55 second on the end of the target time. I compared mine to someone else and his was set to go of at that specific time
Because of the combination of being a cloud-based system and a mesh network, nothing is guaranteed to run at the exact second that you specified. Within one minute one way or the other is considered normal.
http://docs.smartthings.com/en/latest/smartapp-developers-guide/scheduling.html?highlight=Scheduling
SmartThings will try to execute your scheduled job at the specified time, but cannot guarantee it will execute at that exact moment. As a general rule of thumb, you should expect that your job will be called within the minute of scheduled execution. For example, if you schedule a job at 5:30:20 (20 seconds past 5:30) to execute in five minutes, we expect it to be executed at some point in the 5:35 minute.
I don’t know, but they may do some load-balancing as well and slightly offshift different accounts by different amounts.
If you need very precise timing, you’ll need to go to a Wi-Fi based system that runs completely locally and not use SmartThings.
Architecturally, I sure hope they do!
