Absolutely!
At around line 94, or where ever “main” is called, change this:
main ([“contact”])
to this:
main ([“actuate”]) (or what ever you titled multiAttributeTile to be)
Absolutely!
main ([“contact”])
to this:
Absolutely!
main ([“contact”])
to this:
This worked perfect thanks! The only weird thing is the text where it says “last updated…” is gigantic, but I attribute that to an app/iPhone issue.
Hello John
I have scanned the forums and you code looks to be the most update to date.
I just ordered the MIMO2+ which has two relays since I have two garage doors. I spoke with FortrezZ and they said their genic code is working fine to control two relays as listed here:
Would you be so kind as to share what I need to update in your code to adapt it for MIMO2.
Thanks,
Vince
Hi folks!
I’m growing tired of replacing my Linear garage door device controller every year or so and was looking at the Mimo unit.
Can this unit be set to activate a closed command for the door if I should leave a geofence?
Also, does it know the status of the door?
