Wano
(Wanho Im)
1
Hello! I am finding LAN Hue Extended Color Device Handler
Now, I have set up philips hue lamp and Hue Bridge.
I wanted to control hue lamp when a temperature is over some degrees.
So, I used Hue bulb template but it did not work. I realized hub bulb template is different from LAN Extended Color.
Wano
(Wanho Im)
2
I solved this problem myself. I developed SmartApp using Philpse API and hubaction. So I can control my Hue bulb.
tamttt
(Tam Tran)
3
Could you please share your work?
Wano
(Wanho Im)
4
Hi @tamttt
refer to this repository.
tamttt
(Tam Tran)
5
@Wano
Thanks very for your work
