# When will naming multi gang switches (in Edge Drivers) finally be fixed?
**URL:** <https://community.smartthings.com/t/when-will-naming-multi-gang-switches-in-edge-drivers-finally-be-fixed/239319>\
**Category:** Support\
**Tags:** edge-device\
**Created:** [February 9, 2022, 10:39pm UTC](https://community.smartthings.com/t/when-will-naming-multi-gang-switches-in-edge-drivers-finally-be-fixed/239319 "2022-02-09T22:39:20Z")\
**Posts on this page:** 1\
**Showing post:** 9
<div class="post-metadata">
**Author:** ![Brad\_ST](https://yyz2.discourse-cdn.com/smartthings/user_avatar/community.smartthings.com/brad_st/32/15696_2.png) [@Brad\_ST](https://community.smartthings.com/u/Brad_ST)\
**Post date:** [February 10, 2022, 7:36pm UTC](https://community.smartthings.com/t/when-will-naming-multi-gang-switches-in-edge-drivers-finally-be-fixed/239319/9 "2022-02-10T19:36:18Z")
</div>
> [@niquini](#):
> Come on…
I apologized in advance as this is well outside the scope of my day to day job responsibilities at SmartThings. Please understand that the Edge architecture is still in beta and that support offered by non developer-relations individuals such as myself is often on my own time. Your patience is appreciated.
> [@JDRoberts](#):
> Multi component Edge drivers don’t at present allow the user to change the name. Even worse for many users is that only the equivalent of the parent is exposed to Alexa. You can’t control the child components by voice at all.
Thank you. I was not aware of this limitation but this helps me understand the issue at least.
_[View the full topic](https://community.smartthings.com/t/when-will-naming-multi-gang-switches-in-edge-drivers-finally-be-fixed/239319)._
