Yep, I think I read about that trick in one of the smart thermostat installation guides.
Just make sure you label them with what terminal theyāre plugged into at the thermostat end and donāt rely ONLY on the color, as thatās not often as standardized. Better to be safe than sorry.
Take pictures when replacing thermostats, ALWAYS take pictures. Soooooo helpful when the wires are the wrong color.
BTW, some really new thermostats now use only two wires, and communicate to a box closer to the unit. Thermostats have changed over the years, and the standards are very loose. Be careful, you wonāt hurt yourself, but you can make an expensive mistake. Nest has the best install for a thermostat Iāve ever seen (it even detects miswires).
+2 One for AC, One for Heat. Went this router because of no neutral wire but havenāt looked back. They work great.
Iām using a Trane XL624 thermostat. I bought two on Ebay (seller had twoā¦it was a good deal)ā¦guess Iāll sell the second one sometime. So far seems to work fineā¦ST recognized it as a thermostat immediately and the basic device type seemed to work ok. I created my own device type based on some modifications I found from others, then added a tile to show humidity, which the XL624 can do. As with most of these, you need a powered C wire (24v AC), but my Trane system (19i) already had it.
From northern va by chance?..guessing from sn
If so that would make me āsovadudeāā¦alrightā¦so that was cornyā¦anywayā¦
I have a Carrier Infinity system which was installed 2011. I will grab a pic of the thermostat online and update thread so you can see if it is similar to yours.
Chances are yours is the sameā¦if so installation is tricky but not impossible. Initially I had some confusion w/my Ecobee3 due to Infinity system has a 2 wire thermostat and a separate control boxā¦which looks very intimidating.
If more than 2 wires were run up to thermostat youāre in business. All that will be needed is to connect all the wires on the Ecobee ( or thermo of choosing ) and disconnect the control box by joining color to color so that the thermostat wires run straight to the system board.
Basically the Infinity control box is wired in series and is the junction for the wires leading to the outdoor unit.
Iām new to this stuff so can the CT100 really only do one function (heat or AC) at a time or if I have the right wiring do I only need one device?
The CT100 can be set to Cool, Heat or Auto where it automatically switches between cool or heat. I have one CT100 that controls my central air and heat. Mine is set to Auto and I have not had any issues. I am using the Better Thermostat with Battery and Time device type.
Another CT100 user here.
I see on the Radio Thermostat website an all white version of the ct101. Has anyone actually seen it for sale anywhere.
http://www.radiothermostat.com/products/
CT101 is lowes branded CT100 and nearly all the Lowes carry it atleast in Jersey.
I am in northern VA! As for the thermostatā¦ Do you think it makes a difference for the infinity system? You canāt do all the extra things the system can do with its proprietary thermostat, right? Thatās what is stopping me - it has that infinite stage thing.
I wondered the same thing.
From the literature I read the āextra thingsā was a variable speed fanā¦that was it. Ecobee3 has the ability for a 2 speed fan which was fine for me. The added features / benefits of the Ecobee3 was leaps and bounds better than the old technology.
For the extra warm & fuzzy I consulted a friend whom owns his own HVAC service company. He endorsed my feelings on the fan situation (most run all the time full speed any way for circulation).
Any other features / functionality that may have made Carrier Infinity / Bryant Evolution new technology is now commonplace except the variable speed fan.
I have two Zen thermostats. They were easy to install using the Zen online install manual, and it looks like they will work with a lot of different systems. They work just fine, but they have very basic settings themselves, so you definitely need a HA hub to set schedules, etc. They look nice on the wall and are pretty unobtrusive. You have to do some programming of the Zen units to get them to run in Auto (switching between heat and cool) mode, but if you are using ST then that doesnāt really matter and it is easy to do anyway. There are quite a few things you can program with the Zen units.
+1 for CT100. It just works.
Honeywell Wi-Fi thermostat.
Unless you have Infinity/Evolution equipment the inf/evo Thermostat wonāt work. But if you do have the high end communicating inf/evo furnace, going with the factory control is ALWAYS the best bet. I am a Wholesale Carrier Control Technician. I am the factory tech support in chicagoland for the infinity/evolution controls. I am the largest HVACR distributor in the Midwest. I have been involved in the buiz my whole life, but have had a career here for 15 years. Ask me anything.
Accurate energy tracking is still very unique to me (inf/evo) and you cannot get it anywhere outside high end communicating equipment and stats. The only way to get it is to have a full Infinity/Evolution system. Stat, condenser, and furnace need to be communicating. If none of your equipment is Inf/Evo, a INF/EVO STAT WILL NOT OPERATE, as it does not operate as a normal stat with relays to energize the terminals on the furnace for operationā¦ It is a proprietary communication language.
Unless you have a full system installed, comparing infinity/evo to any non communicating stat and equipment is like comparing a Chevy Cavalier to a Ferrari Enzo. They are both cars have 4 wheels, engine, transmission and moves people, but beyond that nothing similar.
The logic in the inf/evo algorithms are exactly that. Algorithms. Not it is hot, cool to 72, turn on.
It operates based on rolling calculations from the last few days to a month, based on past operation to calculate and anticipate at which stage to start and how fast it will need to ramp up cooling or heating stages to effectively and most efficiently cool or heat without you actually feeling the temperature rises and drops, which creates discomfort.
Your nest, turns on when your home, off when you are not, and TRIES to REPLICATE what inf/evo multi stage high efficiency systems do, with a single stage furnace or airā¦ Like i said. Cavalier VS ENZO.
NEST is the biggest joke in the industry. We sell enough dumb stats to techs and home owners that are replacing months old NESTs that could fill a dozen dumpsters. Every nest sold is another sale for a wholesale shop when you call your technician and he diagnoses the issue as the NEST, EVERY TIME. I see more under 1 year old nests being replaced than you can even imagine. People hate them, ESPECIALLY THE PROFESSIONALS that actually know this stuff inside and out, like me. I would never recommend a NEST to my ENEMY, let alone a stranger on the internet, or my own family!
I do nothing but deal with thousands of technicians throughout the year. Every single nest that has been found in the field is replaced to better operate the system. IT is an expensive joke on your a/c unit. Donāt be mean to the thing that works hard every day to make you comfy!
on a side note, Carrier sells the Carrier Cor. An Ecobee designed and manufactured Smart stat. It is gorgeous with capacitive touch screen.
And this is why I use two Honeywell zwave thermostats that Iāve programmed based in my family routines. We stay very comfortable and both thermostats was less than one of those fancy high fedangled thermocraps.
Hi Very Helpful. In the DC Area. MY HVAC installer went out of business. I want to upgrade my evolution thermostats to one that is programmable and that I can control with my iPhone.
Are the Bryant Wifi Thermostats the best option? What about Ecobee?
Here are my stats:
Basement/First Floor
Bryant Evolution Gas Furnace (355CAV042080) and Bryant Evolution Air Conditioner (187BNA036 A), Spaceguard #2410 air cleaner, and AprilAire model 600 humidifier.
Upstairs
Bryant Air Handler (FE4ANF002T) air handler with a 10 kw heater package and a Bryant Evolution Heat Pump (286ANA024) and Spaceguard #2410 air cleaner
JSS
I also have a Bryant Evolution furnace and Bryant Evolution stat (old single-stage AC). I generally run my fan 24 hr/day. I want to replace the Bryant Evolution stat with something that auto-adjusts and can also be adjusted in a well-designed app (or SmartThings).
- Does it have to be replaced with Bryant Evolution if I want to avoid running new wires
- Does the Carrier model that you link also work with the Bryant or do they use different communication protocols?
- What is the cost of something wifi-enabled which will work with the Bryant Evolution protocol? I havenāt been able to find any reasonable prices online and most just point me to a local installer
- I like the Nest App UI and already have one which was given to me. If I run a 2nd heating wire and a common wire, I feel like I should get the functionality Iām looking for.
