What happened to modes?
I haven’t dug in too deep on the update because I just moved and I’m waiting for the new hub before I install everything. However, it looks like I can’t assign apps to modes anymore. Is there a alternative way to do this now?
Modes are still there and can be assigned from apps. You just can’t switch modes without creating a routine to do so.
I must be missing how after the update. I have an app that monitors for low humidity for example. If I open it at the bottom there would be a menu that opened check boxes to select which modes was applicable. Now I don’t see that.
How do I create a new mode?
From main page, menu, then my locations, then the gear, then add new mode.
Ah, thanks. Didn’t drill down far enough.
