[quote=“eric182, post:747, topic:86345, full:true”]
does anyone have any example pistons using the gardenspots and setting random colors?
[/quote]@ady624 had a great one in CoRE that, while not exactly random, changed with the holidays. If and when he converts it to webCoRE, maybe he’ll share?
I’m trying to discriminate upon MiniMote button push sequences, as simple as Push#1 followed in five seconds by a Push#2. The timing may not be reliable due to inherent ST limitations, but I could live with the occasional failure-to-fire.
The first problem I ran into was that the only actions available for a discrete button is gets pushed (or gets held). I was hoping for a pushed in the last 5 seconds. I’d set it to be triggered on a button push but conditioned on another button having been pushed within the previous 5 seconds.
I was able - in either a piston restriction or an IF restriction (example below) – to condition it on the number of buttons changed. Idea being that any button would then be the setup for the specific button trigger.
The logs below show what happens when I hit Button#3 then Button#4. When the piston evaluates the Button#4 push, it doesn’t recognize that another button had been pushed.
Usually, I overthink the logic. Is there a simpler way?
This piston says at the top that it does not Subscribe to any Events, and that it will never run on its own. But it has time triggers. Like do this every morning at 3:59 am. But it failed this morning, so clearly I have something wrong.
Logs gave me this. (It should have run at 3:59) The mode was Night, so it should have been just fine.
2017-5-19 06:59:59 +397ms
+565ms ║Piston execution aborted due to restrictions in effect
2017-5-19 03:57:59 +230ms
+338ms ║Piston execution aborted due to restrictions in effect
2017-5-18 03:57:59 +171ms
+414ms ║Piston execution aborted due to restrictions in effect
FYI :: all of my Pistons that had an action of set level for a light stopped working. I had to go through them all and add turn on first then set level.
The command optimization would interfere with that, yeah, because if the level is already there (you turned them off at that level) then the command is skipped. Disable command optimizations on the piston or add a turn on too.
I’ve got a rather large piston that appears to be stalling at a lengthy timer. That is, one of the execution commands runs a timer and nothing further along in the piston seems to want to run. Is that what the asynchronous command under the cog is for?
Just a shot in the dark here, but try moving your restriction from outside the if to the action. So instead of:
Only when x
Execute
If blah blah
Set mode
Try:
If time blah blah
Then
Only when X
Set mode
No idea if this will have any effect but I’ve had better luck with action restrictions than full statement restrictions when dealing with time triggers. You shouldn’t have that message about no triggers though, something doesn’t seem right about that.
