SmartThings Community
webCoRE Forum Username Policy & Verification
webcore
(Spencer Wagner) #42
I created a webCoRE profile using the same name. It was a week or two ago.
(Baivab) #43
Hello - I have requested access to Webcore community forum using the same user name. Kindly approve. Also, I never did receive the activation email into my gmail account. I did check spam folders also.
(Robin) #44
I can see your un-activated account and have pushed out a new activation email.
Perhaps you typed your email address in wrong… will send you a PM so you can reply with the email you used / should have used.
(Baivab) #45
Hello - thank you. I am checking but do not see any activation request, even in Spam folder. Kindly help in activating the account if possible. Unfortunately, I do not use any alternative email ID I can use.
(Robin) #46
other gmail users have successfully activated since your sign-up so messages are getting through the great wall of G.
Can only suggest you may have miss-typed your address but for data protection reasons I cannot release what was typed here or in a PM.
Send me the email address you intended to type (via private message) and I’ll check they match.
(Rob Lyman) #47
Hello, I am trying to get verification on webcore. the username is RLyman1
(Robin) #48
@RLyman1 is not a name that need to be verified as it is not in use on this forum.
I’ll mark you as non-ST to remove the pending badge (I’m overdue a run through the list otherwise this would have happened already).
(Rob Lyman) #49
Ok thank you
(Dan Jackson) #50
Dan_Jackson1 is my username on web and st, looking forward to learning!
(Michael) #51
Just registered on both sites. User name, hey8you, is the same for both.
(Ryan) #52
I have registered on ST and webCoRE with the same user name.
(Dre) #53
I have registered to ST and webCoRE with the same username.
(Sbaker1106) #54
I have the same username on webcore as here.
(Scott) #55
#56
Hello. I have the same username for SmartThings & webCoRE forums.
(Scott) #57
I created a webCoRE forum account using the same username as I have on Smartthings.
(Freinkelhouse) #58
Smartthings User Name- freinkelhouse
Webcore- Exportedafrican
(adam) #59
I have created a webCoRE account with the same username I have on Smartthings
(Neal (www.zebrablinds.com / www.zebrablinds.ca)) #60
@RobinWinbourne Just created an account. Same username.
(mike) #61
both my usernames are same
