Further to my issue with previousAge()…
Using previousAge([$currentEventDevice : presence]) doesn’t work; never saves
Using the ACTUAL device previousAge([$Pres - Tacoma TRD : presence]) DOES work!! It saves just fine!
I also tried with the 3 main browsers at my disposal (Chrome, IE & Edge) & they all exhibit the same behaviour.
Not being a smart-ass here, but I think there is a newly introduced issue with previousAge([$currentEventDevice : presence]), specifically that $currentEventDevice isn’t “recognized” as valid (for lack of a better description) when used in conjunction with PreviousAge()…
@c1arkbar… If you look at the chain of these comments [start reading at post 150] then you’ll see that if FAILS to save the piston when using previousAge([$currentEventDevice : presence]) ; all you get is the never ending spinning boxes in the lower right corner, so sorry, not physically possible to give a Green Button screen shot… ady624 has confirmed this to be an an (occasional) issue, although this is now 2 days that the issue is present for me.
Here is a piston that tell me how many times a door has been open today, and then grand total opens. I feel happy to make a contribution to this thread.
To think, for the last 30 something years of my life, i never knew how many times my front door opened daily (life was rough!!) Now I know for my front door, kitchen window, Patio door and garage door.
Just set up this piston, but I get these warning messages. Am I doing something wrong? The log looks ok, but it hasn’t actually ran at the specific time yet. I am ignoring the timers one.
Thanks for all your examples. I’m starting to figure all this out.
"Low battery on these devices: " deviceList ". The percentages are: " [deviceList:Battery]
You only need curly brackets inside the value field. In the expression field everything is evaluated already. So you need quotes (double or single just be consistent) around everything you just want it to say. You can use plus (+) signs to add things like you did but it isn’t necessary.
Edit: Looks like you have the same error in your log to console too. Copy the thing above into both. Don’t worry about the timer error.
