Here’s my Motion Sensor Tile Piston below. I disagree that it’s not useful, the motion sensors I use will show as active for a few minutes (configurable on DTH) so it does show relevant data. Thanks to bangali for the Presence Sensor, I took that piston and used parts of it for this piston: [DEPRECATED THREAD: visit community.webcore.co for assistance] WebCoRE - Example Pistons
I’ll look to share the others later tonight if anyone is interested.
Something to note, the tiles do not show until the Motion Sensor is used (Motion) for first time after piston is created. You have to put the Motion Sensor names under the MotionSensorNames Variable on top and name as you like for each one like it’s formatted now. This is helpful if you have longer names so they fit the title of the Tile without resizing to fix (shrinking the text size).
This piston will create gauge tiles and piston state for a HEM.
The piston shows:
Power
Energy
Current (calculated)
Cost (calculated)
You can set your cost per kWh in the variable. Cost is a simple calculation assuming a flat rate per kWh. I believe there’s another example in here that calculates based on time of day.
@ahndee love your battery level piston, but how would I make this piston show what device has the lowest battery level? I’ve been using it for some time now and I like the low battery warning message but in the dashboard it says all battery levels are fine (lowest is 67%) is there a way to make it say for example" (lowest is 67% on the Back Door) " would really appreciate any advice on how to do that one.
Cheers.
I think you may have misunderstood what I meant. Is there a way to modify it so the string that is read out on the dashboard can state which device is the one with the lowest battery level? Rather than having to open the piston and search through loads of devices to try and see which one is the one with the lowest battery level?
Door Status Tiles / Code: s0hd
Note, this is based on bangali’s Presence Sensor and will not display the tiles until the sensor is opened or closed for first time. You may just have to open/close all of your sensors if you want all of them to show right away. You have to modify the DoorNames Variable to the exact name you want the tile to show, very useful if you want to shorten the name to correctly fit the tiles without renaming your devices.
Window Status Tiles / Code: eo786
bfara83
using this piston Window Status Tiles / Code: eo786
If I enter my 13 window sensors in device section I will get 13 tiles displayed?
Thanks Mike
In addition to updating the Windows device variable for your windows, you need to edit the WindowNames string variable to correspond to the thirteen window sensors.
Is there anywhere to get a list of code for all the animations possible for piston state or tiles that can be used.
I’m using one for life ring and spinning life ring, but I got that from someone’s piston example.
I’d love to see a list, and maybe an example page on the wiki
Correct, right now though it doesn’t display until the sensor is triggered for first time after the piston is created. I’ll check if the code can be modified to fix that and will update if I can get that to work
