Thank you, will correct it
v0.0.05d.20170329 - ALPHA - Minor typo fixes, thanks to @rayzurbock
I donât see why heating setpoint would not work. Are you able to look at the DTH code? Put some logs in it?
Does webCoRE report having executed the setHeatingSetpoint command? Does it have a setHeatingSetpoint command? Is it spelled correctly, down to capital letters? Thank you for your help
And Spaceballs the movie, the instant cassette that is out before the filming finished, right?
You seem to havr logging set to minimal, are you expecting a log? Or is the location not changing either? Set logging on medium or full. Method execution shows from medium and up
Will change the loging.
The location does not change, worked yesterday.
Could you enable full logging please?
itâs in the webCoRE app on your phone, under Settings
I was right, me stupid.
Never using that old fasion mobile app anymore
Edit, still there in v0.0.05d
Is time not a trigger? I wanted to make a Piston that if it is between 5:30 PM and 11:00 PM and kitchen light turns on then Dinette light will turn on if thse two conditions were met. But couldnât find time.
Thanks. Good to know.
Heâs taunting us with the one thing that a lot of my pistons need.
Holding out for a big reveal clearly.
Is it fair to assume that global variables donât exist yet? Or is there a different character than @ to make them work? @ady624 I know I said it earlier but wow this thing is just amazing.
Cannot register a browser, always says my code is invalidâŠanyone has an idea?
try again please, subfolder of /tmp did not exist after reboot, now gets recreated automatically
worked perfectly
So, it turns out godaddy blocks outbound port 25 and forces users into using an outbound email relay. Ok, relaying⊠delivery delays of 1+ minutes, and a maximum 1000 emails/day limit. Who knew sending emails could be so complicated?! (pun intended)
