v0.1.0ab.20170517 - BETA M1 - Fixed a bug affecting some users, regarding the new LIFX integration
No fun, you fixed the bug before we can experience it
Following the instructions to install, and Iâve gotten as far as finding webCoRE in the SmartApp Marketplace \ My Apps. I tap that, and get the welcome screen that ends with âIt looks like you are ready to go, please tap Nextâ. But when I tap Next, I get a red box that says âOops! Looks like you need to double check some inputs.â
As I havenât made any inputs yet, I donât think any of them are wrong, though itâs entirely possible I screwed something up in the IDE. What should I be double-checking?
Did you enable the Oath in ide and clicked update?
I would look in ide live logging to see what else that error saysâŠ
Yes, I did. It shows a Client ID/Secret in the app properties, and shows as OAuth=true in the list of SmartApps. No events appear in Live Logging when I get the pop-up.
One thing that looked odd to me during the installation steps â there are four apps in the GitHub repo, but the install instructions only tell you to install three of them. Do I actually need all four?
(ETA: After publishing the fourth one, I get the same error trying to install, so thatâs apparently a separate question.)
Is webCoRE listed in your Smartapps tab, under Automations?
Iâm not sure where you mean. My Dashboard doesnât have a SmartApps tab. The only place it appears in the app so far is in Add \ SmartApp Marketplace \ My Apps. If you mean in the IDE, itâs listed under My SmartApps, but the category is Convenience, not Automation.
Two things, which app in ide have you enabled the Oath? It should be webcore not webcore piston
ANDâŠ
In the mobile app, under Automations/Smartapps do you see webCoRE?
Yes, oAuth is enabled for webCoRE, not any of the sub-apps.
I donât know where that screen would be â I donât appear to have an âAutomationâ tab, or if I do, itâs at a depth I havenât found yet.
oh wow, I havenât seen that version of app in a long time. I sure do miss some of its features. So what app shows under Convenince? Is it webCoRE? And if you access it from there, thatâs where you get the error?
Adrian is pumping things out faster than the wiki can get updated. I will visit the installation pages tonight.
Advantages of SmartThings declining to update the Windows app further, I suppose? Really hoping they get around to a UWP version soon.
No, the app there is Smart Home Ventilation, which Iâm not actually using yet. (Need one more sensor.) I donât think Iâm successfully getting it installed â itâs the install flow that appears from the SAM which is failing; I presume it would appear there if I could successfully complete that flow.
Is that the Windows app? There are some paragraphs marked ârequiredâ to make them red, but they are not really inputsâŠ
Yep, Windows 10 Mobile. Having it be some kind of automated validation makes sense, given that I canât find that âOops!â string in any of the .groovy files.
@eibyer can your piston status do this?
Ha! You can now use :fa-cog: or :fa-cog fa-spin: in a status! Or fa-anything (whatever font awesome supports)!
Who wants to try this?
Set piston status âYour damn fan is like this :fa-superpowers{[fan:switch]==âonâ?â fa-spinâ:ââ}:!â
Ok, so fa-superpowers does not work (older version?) and I found a bug, ââ is not parsed as an empty string, but skipped - bug fixing time!
I want!
