Weather Underground API's?
Is astronomy the only data feature available from Weather Underground? I have been trying to use conditions and get a return of null…makes me think smart things is not subscribed to the conditions API?
Thanks,
Scott
I’m trying to get the local wind speed from weather underground. Here is my code…what am I doing wrong?
def data = getWeatherFeature( "conditions", zipcode )
log.debug( "Current windspeed in ${zipcode} is ${data.wind_mph} mph")
TIA,
Scott
@av8rdude try data.current_observation.wind_mpg
@Dianoga that did the trick! Thanks for the help.
@Dianoga Where did you find the correct api call? I have found their documentation and it doesn’t show the “current_observation” part?
I appreciate your time,
Scott
Oops…the link disappeared:
http://www.wunderground.com/weather/api/d/docs?d=data/conditions
If you look at the json response from wunderground, the field you wanted was enclosed in the current_observation object.
Sorry for bumping an old post…
I would really like to use the data from my particular weather station since where I live (a rural mountainous area) one zip code covers a tremendous area. My station ID is KCALOSGA37 (see http://www.wunderground.com/personal-weather-station/dashboard?ID=KCALOSGA37). Is there a call that references the ID instead of the zip code?
John O
If memory serves, use pws:KCALOSGA37 instead of the zipcode
But I’m not entirely sure. It’s been discussed elsewhere if you want to try searching.
Yep. Station id in place of zip.
