What? I thought only the stock Weather Tile works with ActionTiles!?
This is brand new information to me, too. I had no idea.
I determined that DTHâs are unique by DTH name and namespace. So this SmartWeather Station Tile is created until my developerâs namespace. and can be picked up by ActionTiles⢠as long as it has the same number of fields as the SmartThings version!
Only if you have a Ambient WS like the WS-2902A.
Or any of the network connected Ambient models that report their data to the Ambient network servers should work with STAmbientWeather App.
Here is a link to Ambientâs web page of those compatible models
Kurt is this something I can run without having a pws? Maybe I can use my zip code.
The stock âSmartWeather Station Tileâ from SmartThings allows for a zipcode to be entered in the devices preferences section. Is this what you are asking?
Not action tiles but SmartThings new Samsung app
Wow, I hadnât seen this display as I have not migrated to the new Samsung SmartThings App.
STAmbientWeatherApp, like so many other end userâs applications with custom attributes, are not supported in the new SmartThings Mobile App. The STAmbientWeather app only runs in the classic version of SmartThings mobile client.
SmartThings/Samsung does not {currently} support many of typical weather attributes generated by a weather station, like wind, rain, dewpoint, pressure, feelslike, etc⌠Therefore the only attributes/values that will display in the new SmartThings/Samsung mobile app are the few standard attributes you are seeing that I could map a weather value to.
That is why so many end users are not migrating to the SmartThings new Samsung app.
I hope samsung eventually supports this & other custom apps. Letâs hope they are listeningâŚor reading I should say.
Are you really in a place that is at 47.8C or you are facing a unit issue with F?
Not sure what is running behind your device but one drawback of the new TheWeatherCompany is that you have to guess the units based on your location.
Unit issue. Motion and power! I guess it thinks the rain is motion and solar radiation is power.
@Philippe_Portes: Iâm not sure why the new Samsung SmartThings Mobile App defaults a userâs temperature readings to ÂşC. I am guessing that @RottenMutt is in the USA and it should default UNITS to the value of SmartThings API getTemperatureScale() or leave it blank if it is not sent in the sendEvent. I have not activated the new Samsung SmartThings client since it does not support non standard attributes, so who knows?
@RottenMutt: per STAmbientWeather documentation:
Ambient Weather Custom Attribute Mappings
- Only a subset of Ambient weather attributes can be viewed from ActionTilesâ˘. Per ActionTiles⢠website, ActionTiles⢠only supports Things that are fully compliant with a standard Capability (device type abstraction) as defined by SmartThings Capabilities.
- SmartThings publishes a partial list of âWWSTâ (Works with SmartThings) Certified Devices but not all of those are compatible with ActionTiles, because some of them claim a âCapabilityâ that ActionTiles⢠has not built a Tile Type for.
- Units of measure on ActionTiles⢠cannot be modified
Name of Action Tile Thing (Checkmark) | Ambient Weather Attribute |
Energy Power |
Wind Speed, mph |
Illuminance Measurement | Solar Radiation, lux or w/m² Light, lux or w/m² |
Motion Sensor | Wind Speed > 0 Detected, active |
Relative Humidity Measurement | Outside Relative Humidity, % |
Temperature Measurement | Outside Temperature, °F |
Ultraviolet Index | Ultraviolet Index, uv |
Water Sensor | Rain Detected, wet/dry |
This is in your âLocationâ setting. I have no clue how to change it in the new app (searched for a while) while this was easy to set in the classic app.
I used to have a conversion function to adjust WU results based indeed on the getTemperatureScale() and I was managing the string C/F accordingly.
Now I just call my tiles with:
sendEvent(name: âTWCdewpointlevelâ, value: mymap[âtemperatureDewPointâ], unit: temperatureScale)
where temperatureScale is the result of getTemperatureScale.
In the US, TWC will return F and if I have F it seems working fine. If I change to C, it works also fine.
What I donât know is what happens if you are in a country in Celsius and get Celsius from the TWC report. I suspect the same sendEvent would not work, just like we see in the snapshot we commented.
Thanks @Philippe_PortesâŚGood pointsâŚ
So I wonder if @RottenMuttâs SmartThings location has a value of âCâ forâ Temperature Scaleâ which might explain why in the new Samsung SmartThings App it shows âÂşCâ for a temperature value where UNITS were not indicated on the sendEvent() and should be null?
I am leaning toward using the SmartThings API getTemperatureScale() in next STAmbientWeather (v3.06) to explicitly define the units of measure for Ambient weather data. The Ambient API reports all data in imperial units, and the user can select metric units on their weather console for display.
In STAmbientWeather, the app would need to dynamically calculate all the weather values in metric units if the getTemperatureScale() returned âCâ as well for attributes like wind in KPH, pressure in MMHg and Rain in CM or MM. To add insult to injury, the UNIT does not display in the valueTiles.
The new icons donât have labels but the mapping of the icons can be found here:
Thanks so much for this @Brad_ST - it was just what I needed to fix the weather tile in HousePanel.
The weather tile is now happily restored with the icons back and with the new forecast text fields available as an option via the usual Tile Editor use. Hereâs what our crappy weather looks like today in Michigan!! LOL.
Fahrenheit
I am trying to use SmartWeather to add the ForcastToday text to my ActionTiles. I can get the weather tile that you have. But I just want the ForcastToday text. Is that an api call?
Basicly morning and aft details
def newforcast = getTwcForecast(settings.postcode)
def forcastdetail = "${newforcast.daypart[0].daypartName[0]} - ${newforcast.daypart[0].narrative[0].toString()} \n${newforcast.daypart[0].daypartName[1]} - ${newforcast.daypart[0].narrative[1]}"
sendEvent(name:"UGW_web", value: forcastdetail , displayed:false)
the âUGW_webâ is the tile you have set up to dsiplay the text
All SmartThings published SmartApps and device types have been converted to use the new The Weather Company (TWC) API.
Many individualsâ SmartApps continue to use the old Weather Underground (WU) APIs. Although these APIs have have continued to work since the Jan 1, 2019 shutdown, we were informed by The Weather Company that there will be a firm shutdown on Feb 2, 2019. Calls from these individualsâ SmartApps and devices will start failing after the WU shutdown.
To improve the integrations with Personal Weather Stations (PWS), weâve added a new API to retrieve this data:
def getTwcPwsConditions(stationId)
Return personal weather station data for the specified ID
