For all that are interested, I have completed my SmartApp to control the water heater. So far my testing show that the App is running correctly. This app is based on rboy’s 5-2 Day Thermostat.
Here is the Code
definition(
name: “5-2 Day Water Heater”,
namespace: “Home Systems”,
author: “Jim Allen”,
description: “This App allows to schedule 2 weekday and 2 weekend schedules”,
category: “My Apps”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”,
iconX3Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”)
preferences {
section("Choose Water Heater ") {
input name: “switches”, type: “capability.switch”, multiple: true
section("Monday to Friday Schedule") {
input "time1", "time", title: "Trun On Time Weekdays AM", required: true
input "time2", "time", title: "Turn Off Time Weekdays AM", required: true
input "time3", "time", title: "Turn On Time Weekdays PM", required: true
input "time4", "time", title: "Turn Off Time Weekdays PM", required: true
section("Saturday and Sunday Schedule") {
input "time11", "time", title: "Turn On Time Weekend AM", required: true
input "time21", "time", title: "Turn Off Time Weekend AM", required: true
input "time31", "time", title: "Turn On Time Weekend PM", required: true
input "time41", "time", title: "Turn Off Time Weekend PM", required: true
def installed()
subscribeToEvents()
log.debug “Installed with settings: ${settings}”
def updated()
unsubscribe()
subscribeToEvents()
def subscribeToEvents() {
subscribe(location, modeChangeHandler)
initialize()
// Handle mode changes, reinitialize the current temperature and timers after a mode change, this is to workaround the issue of the last timer firing while in a non running mode, resume operations when supported modes are set
def modeChangeHandler(evt) {
log.debug “Reinitializing thermostat on mode change notification, new mode $evt.value”
//sendNotificationEvent("$thermostat Reinitializing on mode change notification, new mode $evt.value")
initialize()
// This section determines which day it is.
def initialize() {
unschedule()
def calendar = Calendar.getInstance()
calendar.setTimeZone(location.timeZone)
def today = calendar.get(Calendar.DAY_OF_WEEK)
def timeNow = now()
def midnightToday = timeToday("2000-01-01T23:59:59.999-0000", location.timeZone)
log.debug("Current time is ${(new Date(timeNow)).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
log.debug("Midnight today is ${midnightToday.format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
log.trace("Weekday schedule1 ${timeToday(time1, location.timeZone).format("HH:mm z", location.timeZone)}")
log.trace("Weekday schedule2 ${timeToday(time2, location.timeZone).format("HH:mm z", location.timeZone)}")
log.trace("Weekday schedule3 ${timeToday(time3, location.timeZone).format("HH:mm z", location.timeZone)}")
log.trace("Weekday schedule4 ${timeToday(time4, location.timeZone).format("HH:mm z", location.timeZone)}")
log.trace("Weekend schedule1 ${timeToday(time11, location.timeZone).format("HH:mm z", location.timeZone)}")
log.trace("Weekend schedule2 ${timeToday(time21, location.timeZone).format("HH:mm z", location.timeZone)}")
log.trace("Weekend schedule3 ${timeToday(time31, location.timeZone).format("HH:mm z", location.timeZone)}")
log.trace("Weekend schedule4 ${timeToday(time41, location.timeZone).format("HH:mm z", location.timeZone)}")
// This section is where the time/temperature schedule is set
switch (today) {
case Calendar.MONDAY:
case Calendar.TUESDAY:
case Calendar.WEDNESDAY:
case Calendar.THURSDAY:
if (timeNow >= timeToday(time1, location.timeZone).time && timeNow < timeToday(time2, location.timeZone).time) { // Are we between 1st time and 2nd time
schedule(timeToday(time2, location.timeZone), initialize)
log.info("$thermostat Scheduled next adjustment for ${timeToday(time2, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
//sendNotificationEvent("$thermostat Scheduled next adjustment for ${timeToday(time2, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
log.debug "Turning on water heater"
switches.on()
else if (timeNow >= timeToday(time2, location.timeZone).time && timeNow < timeToday(time3, location.timeZone).time) { // Are we between 2nd time and 3rd time
schedule(timeToday(time3, location.timeZone), initialize)
log.info("$thermostat Scheduled next adjustment for ${timeToday(time3, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
//sendNotificationEvent("$thermostat Scheduled next adjustment for ${timeToday(time3, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
log.debug "Turning off water heater"
switches.off()
else if (timeNow >= timeToday(time3, location.timeZone).time && timeNow < timeToday(time4, location.timeZone).time) { // Are we between 3rd time and 4th time
schedule(timeToday(time4, location.timeZone), initialize)
log.info("$thermostat Scheduled next adjustment for ${timeToday(time4, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
//sendNotificationEvent("$thermostat Scheduled next adjustment for ${timeToday(time4, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
switches.on()
else if (timeNow >= timeToday(time4, location.timeZone).time && timeNow < midnightToday.time) { // Are we between 4th time and midnight, schedule next day
schedule(timeToday(time1, location.timeZone) + 1, initialize)
log.info("$thermostat Scheduled next adjustment for ${(timeToday(time1, location.timeZone) + 1).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
//sendNotificationEvent("$thermostat Scheduled next adjustment for ${(timeToday(time1, location.timeZone) + 1).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
switches.off()
else if (timeNow >= (midnightToday - 1).time && timeNow < timeToday(time1, location.timeZone).time) { // Are we between midnight yesterday and 1st time, schedule today
schedule(timeToday(time1, location.timeZone), initialize)
log.info("$thermostat Scheduled next adjustment for ${timeToday(time1, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
//sendNotificationEvent("$thermostat Scheduled next adjustment for ${timeToday(time1, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
switches.on()
break
case Calendar.FRIDAY:
switches.on()
switches.off()
switches.on()
else if (timeNow >= timeToday(time4, location.timeZone).time && timeNow < midnightToday.time) { // Are we between 4th time Friday and midnight, we schedule Saturday
schedule(timeToday(time11, location.timeZone) + 1, initialize)
log.info("$thermostat Scheduled next adjustment for ${(timeToday(time11, location.timeZone) + 1).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
//sendNotificationEvent("$thermostat Scheduled next adjustment for ${(timeToday(time11, location.timeZone) + 1).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
switches.off()
else if (timeNow >= (midnightToday - 1).time && timeNow < timeToday(time11, location.timeZone).time) { // Are we between midnight Friday and 1st time on Saturday, we schedule Saturday
schedule(timeToday(time11, location.timeZone), initialize)
log.info("$thermostat Scheduled next adjustment for ${timeToday(time11, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
//sendNotificationEvent("$thermostat Scheduled next adjustment for ${timeToday(time11, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
switches.on()
break
case Calendar.SATURDAY:
if (timeNow >= timeToday(time11, location.timeZone).time && timeNow < timeToday(time21, location.timeZone).time) { // Are we between 1st time and 2nd time
schedule(timeToday(time21, location.timeZone), initialize)
log.info("$thermostat Scheduled next adjustment for ${timeToday(time21, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
//sendNotificationEvent("$thermostat Scheduled next adjustment for ${timeToday(time21, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
switches.on()
else if (timeNow >= timeToday(time21, location.timeZone).time && timeNow < timeToday(time31, location.timeZone).time) { // Are we between 2nd time and 3rd time
schedule(timeToday(time31, location.timeZone), initialize)
log.info("$thermostat Scheduled next adjustment for ${timeToday(time31, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
//sendNotificationEvent("$thermostat Scheduled next adjustment for ${timeToday(time31, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
switches.off()
else if (timeNow >= timeToday(time31, location.timeZone).time && timeNow < timeToday(time41, location.timeZone).time) { // Are we between 3rd time and 4th time
schedule(timeToday(time41, location.timeZone), initialize)
log.info("$thermostat Scheduled next adjustment for ${timeToday(time41, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
//sendNotificationEvent("$thermostat Scheduled next adjustment for ${timeToday(time41, location.timeZone).format("EEE MMM dd yyyy HH:mm z", location.timeZone)}")
switches.on()
else if (timeNow >= timeToday(time41, location.timeZone).time && timeNow < midnightToday.time) { // Are we between 4th time and midnight, schedule the next day
switches.off()
else if (timeNow >= (midnightToday - 1).time && timeNow < timeToday(time11, location.timeZone).time) { // Are we between midnight yesterday and 1st time, schedule today
switches.on()
break
case Calendar.SUNDAY:
switches.on()
switches.off()
switches.on()
else if (timeNow >= timeToday(time41, location.timeZone).time && timeNow < midnightToday.time) { // Are we between 4th time Sunday and midnight, we schedule Monday
switches.off()
else if (timeNow >= (midnightToday - 1).time && timeNow < timeToday(time1, location.timeZone).time) { // Are we between midnight Sunday and 1st time on Monday, we schedule Monday
switches.on()
break
