I’ve doubled checked and what I have pasted above is all that is in the field.
I don’t know how they work:
- the temperature (0402)
- IAS (0500) motion
- battery (0001)
- Illuminance (0400)
- Yes, it has an occupancy (0406)
I have to know that device sent that information wrong or I don’t understand it.
According to the amazon page it says that the light and tamper do not work with smartthings
- HUB REQUIRED: This Zigbee frient needs a hub in order to connect to your smart home. The Motion Sensor Pro works with Homey, SmartThings and other Zigbee certified hubs. Not all features work with all hubs, SmartThings only supports motion and temperature detection, light and tamper protection are not supported
would have to see the driver logs to see what clusters and attributes it supported. For this you would have to have installed and use the Smartthings CLI
Reinstall it with the driver to see if it is now configured correctly and works
Working apart from illuminance still.
Think I’ll give up and return it. Cheers for your help.
Are you wellcome!
As you want.
but if you want to test with the CLI, to see if it really has luminance I can help you
Let it run for a while with the driver and illuminate it with a flashlight
Hi I’ve the same issue as well. Did anyone get the Lux Working with an Edge Driver ?
Hi Again.
I can produce the Logs for this device. I’ve replicated your driver for testing purposes. I’ll run the logs and past them. Not sure how often the Lux is sent so I’ll leave them running for a while
2022-04-30T20:17:19.388539758+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:17:47.759496105+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:17:47.798015772+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xC4, rssi: -51, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x2A, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x0000 > > >
2022-04-30T20:17:47.869095772+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:17:47.879761105+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-04-30T20:17:47.888412105+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-04-30T20:17:47.923706438+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-04-30T20:17:49.418499106+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:17:50.546633106+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:17:50.631271440+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 12dd37ac-4ab9-4f8c-a266-043f60a223b7 [0x004E] (ZG-204Zl)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x004E, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xC4, rssi: -51, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x57, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0002, DataType: Bitmap16, ZoneStatus: 0x0000 > > > >
2022-04-30T20:17:50.700740773+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:17:50.721682773+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2022-04-30T20:17:50.811468106+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 12dd37ac-4ab9-4f8c-a266-043f60a223b7 [0x004E] (ZG-204Zl)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-04-30T20:17:50.882626440+00:00 DEBUG Zigbee Motion Sensor JG ZG-204Zl device thread event handled
2022-04-30T20:18:19.405083787+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:18:49.487983468+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:19:19.451545149+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:19:49.450535163+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:19:53.538906557+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:19:53.576327258+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xC4, rssi: -51, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x2B, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1637 > > > >
2022-04-30T20:19:53.671206007+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:19:53.698396929+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-04-30T20:19:53.711808298+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.37}}
2022-04-30T20:19:53.750751427+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-04-30T20:20:19.448435190+00:00 INFO Zigbee Motion Sensor JG Doing health check read for [CC76]:0500:0002
2022-04-30T20:20:19.458002638+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xCC76, dest_endpoint: 0x23, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-04-30T20:20:19.483157209+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:20:44.608777347+00:00 TRACE Zigbee Motion Sensor JG Received event with handler capability
2022-04-30T20:20:44.728210347+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received command: {“args”:{},“capability”:“refresh”,“command”:“refresh”,“component”:“main”,“positional_args”:{}}
2022-04-30T20:20:44.784932680+00:00 TRACE Zigbee Motion Sensor JG Found CapabilityCommandDispatcher handler in zigbee-motion
2022-04-30T20:20:44.827044347+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xCC76, dest_endpoint: 0x23, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0021 > > >
2022-04-30T20:20:45.108206680+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xCC76, dest_endpoint: 0x26, profile: 0x0104, cluster: TemperatureMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-04-30T20:20:45.561598014+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xCC76, dest_endpoint: 0x23, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-04-30T20:20:45.887742014+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-04-30T20:20:49.454497682+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:21:01.227445354+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:21:01.274040021+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x9C, rssi: -61, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x2F, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0031, extended_status: 0x00, zone_id: 0x01, delay: 0x0000 > > >
2022-04-30T20:21:01.456049355+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:21:01.498992688+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-04-30T20:21:01.520529021+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“active”}}
2022-04-30T20:21:01.563872688+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-04-30T20:21:02.682285355+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:21:02.711530355+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0xC4, rssi: -51, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x6B, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0021, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-04-30T20:21:02.771601022+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-04-30T20:21:02.848114022+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:21:02.897766689+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xC4, rssi: -51, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x6D, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Int16, MeasuredValue: 1637 > > > >
2022-04-30T20:21:02.950027689+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:21:02.965932689+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-04-30T20:21:02.977186355+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.37}}
2022-04-30T20:21:03.023812022+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-04-30T20:21:03.045606689+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:21:03.058280355+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xC4, rssi: -51, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x6E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0002, ZclStatus: SUCCESS, DataType: Bitmap16, ZoneStatus: 0x0031 > > > >
2022-04-30T20:21:03.096016689+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:21:03.128285355+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2022-04-30T20:21:03.148205355+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“active”}}
2022-04-30T20:21:03.200392022+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-04-30T20:21:19.458608030+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:21:49.458504044+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:22:15.864066390+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:22:15.914050723+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xC0, rssi: -52, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x99, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x0000 > > >
2022-04-30T20:22:15.986421390+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:22:16.013748723+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-04-30T20:22:16.027274723+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-04-30T20:22:16.100130057+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-04-30T20:22:19.467485058+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:22:24.747253728+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:22:24.875722061+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xC4, rssi: -51, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x9A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1662 > > > >
2022-04-30T20:22:25.023589061+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:22:25.169469728+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-04-30T20:22:25.310756728+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.62}}
2022-04-30T20:22:25.797689728+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-04-30T20:22:49.478510739+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:22:51.365509407+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:22:51.374476074+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 12dd37ac-4ab9-4f8c-a266-043f60a223b7 [0x004E] (ZG-204Zl)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x004E, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xC4, rssi: -51, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x58, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0002, DataType: Bitmap16, ZoneStatus: 0x0000 > > > >
2022-04-30T20:22:51.391273740+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:22:51.396653740+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2022-04-30T20:22:51.403217407+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 12dd37ac-4ab9-4f8c-a266-043f60a223b7 [0x004E] (ZG-204Zl)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-04-30T20:22:51.422020740+00:00 DEBUG Zigbee Motion Sensor JG ZG-204Zl device thread event handled
2022-04-30T20:22:55.678861409+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:22:55.738318742+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xC4, rssi: -51, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x9B, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1675 > > > >
2022-04-30T20:22:55.793484076+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:22:55.820614076+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-04-30T20:22:55.828263742+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.75}}
2022-04-30T20:22:55.870485409+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-04-30T20:23:02.586386746+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:23:02.609478079+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xC0, rssi: -52, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x9E, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0031, extended_status: 0x00, zone_id: 0x01, delay: 0x0000 > > >
2022-04-30T20:23:02.638073079+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:23:02.643464746+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-04-30T20:23:02.649941412+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“active”}}
2022-04-30T20:23:02.668930079+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-04-30T20:23:19.478480087+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-04-30T20:23:26.725196757+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-04-30T20:23:26.758217757+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xC4, rssi: -51, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xE3, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1693 > > > >
2022-04-30T20:23:26.800139091+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-04-30T20:23:26.818334091+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-04-30T20:23:26.832903091+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.93}}
2022-04-30T20:23:26.875344091+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
listening for logs… done
I don’t know what driver you have generated or used, zigbee motion sensor Mc?
The problem I saw in this device is that it doesn’t have the illuminance cluster, so I don’t know how it sends that information.
However it has the occupancy cluster.
In order to see illuminance messages in the logs you have to add that capability in the profile of that device.
42.x libraries already have defaults for illuminance and in the logs you can see in the installation if that cluster/attribute is supported or not by the sensor.
I already had the pc turned off to give you more information, but tomorrow if you want we will continue seeing new logs
If it is not supported you will see something similar to this for battery attribute 0x0021:
Good Morning, Yes I have amended your Motion sensor MC as below and the Motion/Temp/Battery are all working. But the illuminance isn’t registering. I will look out for the UNSUPPORTED_ATTRIBUTE and leave it running for a longer period of time.
- id: “MOSZB-141/Motion”
deviceLabel: frient A/S Motion Sensor
manufacturer: frient A/S
model: MOSZB-141
deviceProfileName: motion-illuminance-battery
Select a driver. 19
2022-05-01T08:06:01.755283145+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:06:31.758106160+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:06:34.184943161+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:06:34.289640161+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xA4, rssi: -59, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xED, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0031, extended_status: 0x00, zone_id: 0x01, delay: 0x0000 > > >
2022-05-01T08:06:34.392210827+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:06:34.420140494+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:06:34.474387827+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“active”}}
2022-05-01T08:06:34.515220494+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:06:54.418873504+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:06:54.438325837+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0x8C, rssi: -65, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xF7, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1631 > > > >
2022-05-01T08:06:54.472328837+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:06:54.488584837+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T08:06:54.496203504+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.31}}
2022-05-01T08:06:54.548343170+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:06:57.495626838+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:06:57.504487505+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x8C, rssi: -65, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0xF8, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x0000 > > >
2022-05-01T08:06:57.521437838+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:06:57.526978505+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:06:57.533626172+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:06:57.552487172+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:07:01.784032841+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:07:21.787644850+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:07:21.798293850+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xFC, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0031, extended_status: 0x00, zone_id: 0x01, delay: 0x0000 > > >
2022-05-01T08:07:21.818276850+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:07:21.824015517+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:07:21.834053517+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“active”}}
2022-05-01T08:07:21.857921850+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:07:31.808652855+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:07:45.228670861+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:07:45.240562861+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x8C, rssi: -65, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x0D, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x0000 > > >
2022-05-01T08:07:45.274746861+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:07:45.282926861+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:07:45.290099195+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:07:45.308342195+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:07:55.459028533+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:07:55.503675533+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0x8C, rssi: -65, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0E, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1643 > > > >
2022-05-01T08:07:55.521077533+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:07:55.526730199+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T08:07:55.533539533+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.43}}
2022-05-01T08:07:55.552302199+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:08:01.801138386+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:08:31.796238509+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:09:01.838463180+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:09:31.818059850+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:10:01.851297853+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:10:31.863062190+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:11:01.842995194+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:11:31.870481864+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:12:01.880075868+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:12:31.879539481+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:12:45.469203487+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:12:45.511241487+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xB8, rssi: -54, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x12, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x04B0 > > >
2022-05-01T08:12:45.528492154+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:12:45.533912821+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:12:45.540559821+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:12:45.558871821+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:12:55.728797492+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:12:55.738284492+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xBC, rssi: -53, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x13, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1643 > > > >
2022-05-01T08:12:55.755772159+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:12:55.763774492+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T08:12:55.771003159+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.43}}
2022-05-01T08:12:55.798699492+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:13:01.902398495+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:13:31.968234176+00:00 INFO Zigbee Motion Sensor JG Doing health check read for [CC76]:0500:0002
2022-05-01T08:13:32.048694176+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xCC76, dest_endpoint: 0x23, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-05-01T08:13:32.101103176+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:14:01.974060190+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:14:31.948122538+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:15:01.923997886+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:15:32.089625900+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:16:01.951988581+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:16:31.980114644+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:17:01.968052648+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:17:32.007132318+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:17:45.718647319+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:17:45.748935653+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xB8, rssi: -54, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x15, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x0960 > > >
2022-05-01T08:17:45.776207319+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:17:45.785178653+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:17:45.798312986+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:17:45.838713986+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:17:55.978639321+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:17:55.988603987+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xBC, rssi: -53, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x16, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1643 > > > >
2022-05-01T08:17:56.008327987+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:17:56.016320321+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T08:17:56.026928987+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.43}}
2022-05-01T08:17:56.049333987+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:18:01.988040655+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:18:32.069321992+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:19:02.008073662+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:19:32.070093332+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:20:02.033996002+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:20:32.083079359+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:21:02.112823811+00:00 INFO Zigbee Motion Sensor JG Doing health check read for [CC76]:0500:0002
2022-05-01T08:21:02.187913144+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xCC76, dest_endpoint: 0x23, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-05-01T08:21:02.258788478+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:21:32.107338492+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:22:02.064943839+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:22:32.117695187+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:22:45.938841194+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:22:45.958317527+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xB8, rssi: -54, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x17, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x0E10 > > >
2022-05-01T08:22:45.998244527+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:22:46.004735527+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:22:46.017538527+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:22:46.059815527+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:22:56.218632532+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:22:56.228074199+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xBC, rssi: -53, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x18, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1643 > > > >
2022-05-01T08:22:56.248917532+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:22:56.258270532+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T08:22:56.265391199+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.43}}
2022-05-01T08:22:56.287981865+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:23:02.071966201+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:23:32.074108549+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:24:02.148243230+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:24:32.139157696+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:25:02.097656710+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:25:32.108057724+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:26:02.206265738+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:26:32.135024419+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:27:02.176075434+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:27:32.138082448+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:27:46.228643455+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:27:46.315259788+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xB8, rssi: -54, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x19, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x12C0 > > >
2022-05-01T08:27:46.354950121+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:27:46.365593455+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:27:46.380010455+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:27:46.434707788+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:27:56.458895126+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:27:56.480364793+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xB8, rssi: -54, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1643 > > > >
2022-05-01T08:27:56.518510460+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:27:56.529580126+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T08:27:56.538434460+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.43}}
2022-05-01T08:27:56.580716793+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:28:02.148039129+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:28:32.148118370+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:29:02.158110051+00:00 INFO Zigbee Motion Sensor JG Doing health check read for [CC76]:0500:0002
2022-05-01T08:29:02.306996717+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xCC76, dest_endpoint: 0x23, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-05-01T08:29:02.384829051+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:29:32.168131065+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:30:02.183046413+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:30:32.172011093+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:31:02.175038108+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:31:32.241470789+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:32:02.182982136+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:32:32.232044867+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:32:46.385047207+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:32:46.428448540+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xB8, rssi: -54, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x1C, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x1770 > > >
2022-05-01T08:32:46.518278540+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:32:46.590961207+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:32:46.668786207+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:32:46.758085541+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:32:56.678995879+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:32:56.726680879+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xB8, rssi: -54, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1D, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1643 > > > >
2022-05-01T08:32:56.789563545+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:32:56.814860545+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T08:32:56.834133545+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.43}}
2022-05-01T08:32:56.867199545+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:33:02.207106881+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:33:32.289309896+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:34:02.278239577+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:34:32.288735258+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:35:02.234991938+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:35:32.340108953+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:36:02.262994634+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:36:32.329882316+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:37:02.388291053+00:00 INFO Zigbee Motion Sensor JG Doing health check read for [CC76]:0500:0002
2022-05-01T08:37:02.585719054+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xCC76, dest_endpoint: 0x23, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-05-01T08:37:02.727257387+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:37:32.351049068+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:37:46.588623741+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:37:46.658393741+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xBC, rssi: -53, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x1E, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x1C20 > > >
2022-05-01T08:37:46.768279075+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:37:46.830509075+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:37:46.867199741+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:37:47.019123075+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:37:56.888621079+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:37:57.082672746+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xBC, rssi: -53, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1F, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1643 > > > >
2022-05-01T08:37:57.210977746+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:37:57.268994080+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T08:37:57.395405746+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.43}}
2022-05-01T08:37:57.512580413+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:38:02.265068082+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:38:32.387794763+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:39:02.296027777+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:39:32.441273125+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:40:02.486048473+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:40:32.480207221+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:41:02.441972902+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:41:32.454971583+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:42:02.638289930+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:42:32.670885611+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:42:46.818641952+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:42:46.884229618+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xB8, rssi: -54, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x20, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x20D0 > > >
2022-05-01T08:42:46.971658618+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:42:47.000997618+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:42:47.030259618+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:42:47.175823952+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:42:57.118860956+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:42:57.190030957+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xB8, rssi: -54, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x21, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1643 > > > >
2022-05-01T08:42:57.295380623+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:42:57.337682957+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T08:42:57.452137957+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.43}}
2022-05-01T08:42:57.660133957+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:43:02.445968626+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:43:32.700277307+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:44:02.478104321+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:44:32.789895453+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:45:02.819062467+00:00 INFO Zigbee Motion Sensor JG Doing health check read for [CC76]:0500:0002
2022-05-01T08:45:03.151844801+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xCC76, dest_endpoint: 0x23, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-05-01T08:45:03.223812801+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:45:20.995567476+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:45:21.049441809+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xB8, rssi: -54, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x3E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0002, ZclStatus: SUCCESS, DataType: Bitmap16, ZoneStatus: 0x0030 > > > >
2022-05-01T08:45:21.078061809+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:45:21.107082809+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2022-05-01T08:45:21.119919143+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:45:21.159167143+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:45:32.625233815+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:46:02.457356496+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:46:32.854706510+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:47:02.747244524+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:47:32.862990539+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:47:47.060174212+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:47:47.137033879+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xB8, rssi: -54, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x23, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x2580 > > >
2022-05-01T08:47:47.418820879+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:47:47.560482546+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:47:47.718319546+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:47:48.095235213+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:47:57.389325550+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:47:57.567521217+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xB8, rssi: -54, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x24, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1643 > > > >
2022-05-01T08:47:57.898263884+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:47:57.927917884+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T08:47:57.955446217+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.43}}
2022-05-01T08:47:58.000080884+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:48:02.701210553+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:48:32.978387794+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:49:02.879504475+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:49:32.464002155+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:50:02.952442170+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:50:32.996796517+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:51:03.692743865+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:51:06.881609200+00:00 TRACE Zigbee Motion Sensor JG Received event with handler device_lifecycle
2022-05-01T08:51:06.923770534+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received lifecycle event: infoChanged
2022-05-01T08:51:07.032024534+00:00 TRACE Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received unhandled lifecycle event: infoChanged
2022-05-01T08:51:07.087913200+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:51:32.576025213+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:52:04.130494228+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:52:32.527125235+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:52:47.298631984+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:52:47.311068984+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xB8, rssi: -54, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x25, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x2A30 > > >
2022-05-01T08:52:47.343492651+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:52:47.354740651+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T08:52:47.361749317+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T08:52:47.380279984+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:52:57.638641322+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T08:52:57.648514989+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xB8, rssi: -54, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x26, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1643 > > > >
2022-05-01T08:52:57.664604989+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T08:52:57.707896322+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T08:52:57.728266322+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:16.43}}
2022-05-01T08:52:57.840046322+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T08:53:02.615995658+00:00 INFO Zigbee Motion Sensor JG Doing health check read for [CC76]:0500:0002
2022-05-01T08:53:02.937782992+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xCC76, dest_endpoint: 0x23, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-05-01T08:53:03.184673658+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:53:32.548192339+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:54:04.194007354+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:54:34.184219035+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:55:04.133104383+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T08:55:34.153090397+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
listening for logs… /
Let’s see if this helps you
In this case, the most important thing in the log is seen when the first device is installed in the driver or a new version of the driver is updated, with some change in the code, if you do not change anything, it sees that it is the same and it is not installed again:
- The first thing you will see is the information of all the lifecycle handlers that the main module and all the subdrivers have:
2022-05-01T09:54:41.815953080+00:00 TRACE Zigbee Motion Sensor test Setup driver zigbee-motion with lifecycle handlers:
DeviceLifecycleDispatcher: zigbee-motion
default_handlers:
doConfigure:
driverSwitched:
infoChanged:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion → Aurora Motion Sensor
default_handlers:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion → ikea motion sensor
default_handlers:
doConfigure:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion → Iris Motion Handler
default_handlers:
doConfigure:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion → GatorSystem Handler
default_handlers:
doConfigure:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion → Motion Timeout Handler
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion → NYCE Motion Handler
default_handlers:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion → zigbee plugin motion sensor
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion → SmartThings multi sensor
default_handlers:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion → MultiSensor
default_handlers:
doConfigure:
child_dispatchers:
- Then you will see capabilities handlers and attributes of the main module and each subdriver:
2022-05-01T09:54:41.826193414+00:00 TRACE Zigbee Motion Sensor test Setup driver zigbee-motion with Capability handlers:
CapabilityCommandDispatcher: zigbee-motion
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion → Aurora Motion Sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion → ikea motion sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion → Iris Motion Handler
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion → GatorSystem Handler
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion → Motion Timeout Handler
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion → NYCE Motion Handler
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion → zigbee plugin motion sensor
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion → SmartThings multi sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion → MultiSensor
default_handlers:
child_dispatchers:
- Now you see All cluster handlers and their attributes that main driver module and each subdriver has:
2022-05-01T09:54:41.842727747+00:00 TRACE Zigbee Motion Sensor test Setup driver zigbee-motion with Zigbee handlers:
ZigbeeMessageDispatcher: zigbee-motion
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryVoltage
ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
ZclClusterAttributeValueHandler: cluster: RelativeHumidity, attribute: MeasuredValue
ZclClusterAttributeValueHandler: cluster: IlluminanceMeasurement, attribute: MeasuredValue
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion → Aurora Motion Sensor
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion → ikea motion sensor
default_handlers:
attr:
global:
cluster:
ZclClusterCommandHandler: cluster: OnOff, command: OnWithTimedOff
zdo:
ZdoHandler
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion → Iris Motion Handler
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion → GatorSystem Handler
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion → Motion Timeout Handler
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion → NYCE Motion Handler
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: OccupancySensing, attribute: Occupancy
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion → zigbee plugin motion sensor
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion → SmartThings multi sensor
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion → MultiSensor
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
- If you have the Illuminance capability and it does not support it, you will see the corresponding error. Here I put Illuminance capability, (cluster 0x0400) in a profile that does not have so you can see the error that I show and that you should see too:
2022-05-01T09:54:41.891592080+00:00 WARN Zigbee Motion Sensor test Device does not support cluster 0x0400 not adding configured attribute
2022-05-01T09:54:41.898126747+00:00 INFO Zigbee Motion Sensor test Device does not support cluster 0x0400 not adding monitored attribute
Show the information of the installed devices:
- Manufacturer and model:
2022-05-01T09:54:41.904718414+00:00 TRACE Zigbee Motion Sensor test Zigbee Device: dba21d2f-0a43-4260-97f1-4abffcc0d4cc
Manufacturer: _TZ1800_fcdjzz3s Model: TY0202
- All the clusters of each one, you would have to see the illuminance one, if you don’t see it, it doesn’t have it: VERY IMPORTAN INFORMATION OF DEVICE
[1]: Basic, PowerConfiguration, Identify, IASZone, Diagnostics
Then the lifecycle Handlers start executing:
- Init:
- Added:
- driverSwitched
- infoChanged
- Configure:
- It will try to configure the clusters and their attributes so that they send the periodic reports by default or the personalized ones that you send.
If attribute configuration is fine then device respond with status SUCCESS >>>>
- If you have the Illuminance capability and it does not support it, not configuration for illuminance sent to device
2022-05-01T10:31:11.700039350+00:00 INFO Zigbee Motion Sensor test <ZigbeeDevice: dba21d2f-0a43-4260-97f1-4abffcc0d4cc [0xB952] (Sensor Mov. Portal)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB952, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: BC33ACFFFE63FEBB, src_endpoint: 0x01, cluster: PowerConfiguration, dest_addr_mode: 0x03, dest_address: 286D97000204B680, dest_endpoint: 0x01 > > >
2022-05-01T10:31:11.730965350+00:00 INFO Zigbee Motion Sensor test <ZigbeeDevice: dba21d2f-0a43-4260-97f1-4abffcc0d4cc [0xB952] (Sensor Mov. Portal)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB952, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0021, DataType: Uint8, minimum_reporting_interval:
0x001E, maximum_reporting_interval: 0x5460, reportable_change: 0x01 > > > >
2022-05-01T10:31:11.748687684+00:00 INFO Zigbee Motion Sensor test <ZigbeeDevice: dba21d2f-0a43-4260-97f1-4abffcc0d4cc [0xB952] (Sensor Mov. Portal)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB952, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: BC33ACFFFE63FEBB, src_endpoint: 0x01, cluster: IASZone, dest_addr_mode: 0x03, dest_address: 286D97000204B680, dest_endpoint: 0x01 > > >
2022-05-01T10:31:11.773845017+00:00 INFO Zigbee Motion Sensor test <ZigbeeDevice: dba21d2f-0a43-4260-97f1-4abffcc0d4cc [0xB952] (Sensor Mov. Portal)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB952, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0002, DataType: Bitmap16, minimum_reporting_interval: 0x001E,
maximum_reporting_interval: 0x012C > > > >
2022-05-01T10:31:11.815712017+00:00 INFO Zigbee Motion Sensor test <ZigbeeDevice: dba21d2f-0a43-4260-97f1-4abffcc0d4cc [0xB952] (Sensor Mov. Portal)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB952, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0010, DataType: IEEEAddress, data: 286D97000204B680 > > > >
2022-05-01T10:31:11.833644350+00:00 INFO Zigbee Motion Sensor test <ZigbeeDevice: dba21d2f-0a43-4260-97f1-4abffcc0d4cc [0xB952] (Sensor Mov. Portal)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB952, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x00 >, < ZoneEnrollResponse || EnrollResponseCode: SUCCESS, zone_id: 0x00 > > >
2022-05-01T10:31:11.845169017+00:00 DEBUG Zigbee Motion Sensor test Sensor Mov. Portal device thread event handled
2022-05-01T10:31:11.850930684+00:00 TRACE Zigbee Motion Sensor test Received event with handler environment_info
2022-05-01T10:31:11.863794017+00:00 DEBUG Zigbee Motion Sensor test Z-Wave hub node ID environment changed.
2022-05-01T10:31:25.233815357+00:00 TRACE Zigbee Motion Sensor test Received event with handler zigbee
2022-05-01T10:31:25.245350023+00:00 INFO Zigbee Motion Sensor test <ZigbeeDevice: dba21d2f-0a43-4260-97f1-4abffcc0d4cc [0xB952] (Sensor Mov. Portal)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB952, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x7C, rssi: -69, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x27, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0002, DataType: Bitmap16, ZoneStatus: 0x0020 > > > >
2022-05-01T10:31:25.263792357+00:00 TRACE Zigbee Motion Sensor test Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T10:31:25.269632690+00:00 INFO Zigbee Motion Sensor test Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2022-05-01T10:31:25.283810357+00:00 INFO Zigbee Motion Sensor test <ZigbeeDevice: dba21d2f-0a43-4260-97f1-4abffcc0d4cc [0xB952] (Sensor Mov. Portal)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T10:31:25.305668024+00:00 DEBUG Zigbee Motion Sensor test Sensor Mov. Portal device thread event handled
2022-05-01T10:31:26.640755357+00:00 TRACE Zigbee Motion Sensor test Received event with handler zigbee
2022-05-01T10:31:26.668902024+00:00 INFO Zigbee Motion Sensor test <ZigbeeDevice: dba21d2f-0a43-4260-97f1-4abffcc0d4cc [0xB952] (Sensor Mov. Portal)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB952, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x7C, rssi: -69, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x39, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-05-01T10:31:26.690125024+00:00 DEBUG Zigbee Motion Sensor test Sensor Mov. Portal device thread event handled
2022-05-01T10:31:26.697400691+00:00 TRACE Zigbee Motion Sensor test Received event with handler zigbee
2022-05-01T10:31:26.710159358+00:00 INFO Zigbee Motion Sensor test <ZigbeeDevice: dba21d2f-0a43-4260-97f1-4abffcc0d4cc [0xB952] (Sensor Mov. Portal)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB952, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x7C, rssi: -69, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x3A, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2022-05-01T10:31:26.726030691+00:00 DEBUG Zigbee Motion Sensor test Sensor Mov. Portal device thread event handled
2022-05-01T10:31:28.226553358+00:00 TRACE Zigbee Motion Sensor test Received event with handler zigbee
2022-05-01T10:31:28.250993358+00:00 INFO Zigbee Motion Sensor test <ZigbeeDevice: dba21d2f-0a43-4260-97f1-4abffcc0d4cc [0xB952] (Sensor Mov. Portal)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB952, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x7C, rssi: -69, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x38, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
C:\SmartThings>smartthings edge:drivers:logcat
? Enter hub IP address with optionally appended port number:
│ # │ Driver Id │ Name │
│ 1 │ 5964d4b5-2741-40da-8e21-42e1ae6f53a2 │ Hue Dimmer Switch │
│ 2 │ 6324d242-8006-4014-8d03-dc05ba480113 │ Hue Dimmer Switch │
│ 3 │ 07b6ece0-664e-4bda-8933-078cb1bc3326 │ Ikea Styrbar Remote │
│ 4 │ ad16b441-873e-443a-bd56-1885451919de │ ST-Zigbee Moisture Sensor Mc-(OLD) │
│ 5 │ 59cae0e2-63e8-4f85-baeb-d64f431d4232 │ ST-Zigbee Motion Sensor Mc │
│ 6 │ 0fd9a9a4-8863-4a83-97a7-5a288ff0f5a6 │ Virtual Devices V2 │
│ 7 │ 054cf51f-0171-4d25-acd2-9dc739cce921 │ Virtual Things Edge Driver [YG] │
│ 8 │ 8a5a5586-aa12-4cbb-b7ed-fa3ad735df0d │ Zigbee Aqara Water Leak Sensor Mc │
│ 9 │ 89825e62-221d-4174-8512-e8389cc7df3d │ Zigbee Contact Ecolink Mc │
│ 10 │ a89371c4-8765-404b-9de9-e9882cc48bd8 │ Zigbee Dimmer Driver [YG] │
│ 11 │ 737ab493-d750-47fb-8e44-cd1c696d6124 │ Zigbee Light Multifunction Group Mc-(OLD) │
│ 12 │ 69910499-07df-475b-b246-d758f2efbd28 │ Zigbee Light Multifunction Mc-(OLD) │
│ 13 │ efbe7be3-ab36-46eb-86e8-53ac056a1cec │ Zigbee Light Multifunction Mc-(OLD) │
│ 14 │ deec9bb3-224b-46b9-a09b-1b3f56995df6 │ Zigbee Light Multifunction Mc-(OLD) │
│ 15 │ 1d775bca-be15-4cdd-b942-ce23179c8a92 │ Zigbee Light Multifunction Mc-(OLD) │
│ 16 │ c2a45064-5af3-4c60-9525-b318483ea703 │ Zigbee Light Multifunction-Tr-Time-(OLD) │
│ 17 │ 80157078-ade2-41ad-bb00-edb59df25e99 │ Zigbee Light/Switch │
│ 18 │ d620900d-f7bc-4ab5-a171-6dd159872f7d │ Zigbee Motion Sensor │
│ 19 │ 6cdc9f82-b69c-4261-b481-c9a695e6deac │ Zigbee Motion Sensor JG │
│ 20 │ 0e362494-39f0-4f36-a57b-e62afa81fbb1 │ Zigbee Motion Sensor Mc-(OLD) │
│ 21 │ 3c2202c6-bfde-4074-9f7e-a634c0895c22 │ Zigbee Multi Gang Switch Edge Driver [YG] │
│ 22 │ c6008edc-9630-465a-a4ea-0c6432c677fc │ Zigbee Multi Gang Switch Edge Driver v7.2 [YG] │
│ 23 │ 950d769e-5e53-4cb9-aad7-b7b6023f20d2 │ Zigbee Multi Switch Zemismart Mc-(OLD) │
│ 24 │ acc32aef-5966-4bf9-a506-00841a3b5d0c │ Zigbee Power/Meter │
│ 25 │ 59259997-a263-431f-ad7b-ddc8d2776e98 │ Zigbee RGB-RGBW Light Mc │
│ 26 │ 5ab64dc7-5d08-44a4-9806-5a5b823a18d2 │ Zigbee Sensors Edge Driver [YG] │
│ 27 │ a2f7ec78-14c8-492d-9965-7544b0fc3b68 │ Zigbee Smoke Detector Mc │
│ 28 │ b0879f79-e81d-4c5f-aebd-4f1c5f4f2fd4 │ Zigbee Switch Mc-(OLD) │
│ 29 │ f732925a-9ae3-462a-9641-f03f474c661e │ Zigbee Switch Power Mc │
│ 30 │ f72a817f-7181-4538-8ef3-e932343a03de │ Zigbee Switch Power Mc-(OLD) │
│ 31 │ 0998de7a-38b0-4728-8f9e-7b8c18d29ba1 │ Zigbee Temp Sensor with Thermostat Mc-(OLD) │
? Select a driver. 19
2022-05-01T11:36:16.252390973+00:00 TRACE Zigbee Motion Sensor JG Setup driver zigbee-motion with lifecycle handlers:
default_handlers:
doConfigure:
driverSwitched:
child_dispatchers:
default_handlers:
added:
child_dispatchers:
default_handlers:
doConfigure:
added:
child_dispatchers:
default_handlers:
init:
child_dispatchers:
default_handlers:
doConfigure:
added:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
init:
child_dispatchers:
default_handlers:
child_dispatchers:
2022-05-01T11:36:16.261900549+00:00 TRACE Zigbee Motion Sensor JG Setup driver zigbee-motion with Capability handlers:
default_handlers:
refresh:
refresh
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
refresh:
refresh
child_dispatchers:
2022-05-01T11:36:16.294614850+00:00 TRACE Zigbee Motion Sensor JG Setup driver zigbee-motion with Zigbee handlers:
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: LocalTemperature
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
ZdoHandler
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
2022-05-01T11:36:16.410418253+00:00 TRACE Zigbee Motion Sensor JG Zigbee Device: 0835ef81-3875-45d7-aff0-97cfc52535f3
Manufacturer: frient A/S Model: MOSZB-140
[1]: Identify, Scenes, OnOff [34]: Basic, Identify, OccupancySensing [38]: Basic, Identify, TemperatureMeasurement [35]: Basic, PowerConfiguration, Identify, BasicInput, PollControl, IASZone
2022-05-01T11:36:16.432278651+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T11:36:16.438124726+00:00 TRACE Zigbee Motion Sensor JG Received event with handler _resync
2022-05-01T11:36:16.445307466+00:00 TRACE Zigbee Motion Sensor JG Received event with handler environment_info
2022-05-01T11:36:16.531098216+00:00 TRACE Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received unhandled lifecycle event: init
2022-05-01T11:36:16.677569277+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T11:36:16.776248913+00:00 TRACE Zigbee Motion Sensor JG Received event with handler environment_info
2022-05-01T11:36:16.857451625+00:00 DEBUG Zigbee Motion Sensor JG Z-Wave hub node ID environment changed.
2022-05-01T11:36:16.880326515+00:00 TRACE Zigbee Motion Sensor JG Received event with handler driver_lifecycle
2022-05-01T11:36:16.993258354+00:00 TRACE Zigbee Motion Sensor JG Received event with handler driver_lifecycle
2022-05-01T11:36:17.072367462+00:00 TRACE Zigbee Motion Sensor JG Received event with handler device_lifecycle
2022-05-01T11:36:17.156542890+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received lifecycle event: added
2022-05-01T11:36:17.215973149+00:00 TRACE Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received unhandled lifecycle event: added
2022-05-01T11:36:17.306554475+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T11:36:17.345927938+00:00 TRACE Zigbee Motion Sensor JG Received event with handler device_lifecycle
2022-05-01T11:36:17.359464535+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received lifecycle event: driverSwitched
2022-05-01T11:36:17.398098535+00:00 TRACE Zigbee Motion Sensor JG Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-05-01T11:36:17.439138539+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T11:36:17.483568606+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T11:36:17.949208721+00:00 TRACE Zigbee Motion Sensor JG Received event with handler device_lifecycle
2022-05-01T11:36:17.985075485+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received lifecycle event: infoChanged
2022-05-01T11:36:18.008393048+00:00 TRACE Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received unhandled lifecycle event: infoChanged
2022-05-01T11:36:18.018911249+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T11:36:22.828642534+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T11:36:22.845004534+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x88, rssi: -66, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0xCC, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x04B0 > > >
2022-05-01T11:36:22.877675201+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T11:36:22.883771201+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T11:36:22.890606867+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T11:36:22.908329867+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T11:36:46.361604879+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T11:36:53.917090216+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T11:36:53.928314882+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x26, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0x88, rssi: -66, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xCD, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1987 > > > >
2022-05-01T11:36:53.955526216+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T11:36:53.961970216+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-05-01T11:36:53.968641216+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:19.87}}
2022-05-01T11:36:53.986516882+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
listening for logs… \
I’ve deleted and re-installed the driver. and then re-added the device. See results below. I’m afraid it is beyond my skills to know what it is doing.
2022-05-01T12:00:52.156425551+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T12:01:13.998783561+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T12:01:19.540432231+00:00 TRACE Zigbee Motion Sensor JG Received event with handler device_lifecycle
2022-05-01T12:01:19.588920231+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received lifecycle event: removed
2022-05-01T12:01:19.696675564+00:00 TRACE Zigbee Motion Sensor JG Received event with handler driver_lifecycle
2022-05-01T12:01:19.718598897+00:00 TRACE Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received unhandled lifecycle event: removed
2022-05-01T12:01:19.737505231+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T12:01:19.766767564+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T12:02:51.063976608+00:00 TRACE Zigbee Motion Sensor JG Setup driver zigbee-motion with lifecycle handlers:
default_handlers:
doConfigure:
driverSwitched:
child_dispatchers:
default_handlers:
added:
child_dispatchers:
default_handlers:
added:
doConfigure:
child_dispatchers:
default_handlers:
init:
child_dispatchers:
default_handlers:
added:
doConfigure:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
init:
child_dispatchers:
default_handlers:
child_dispatchers:
2022-05-01T12:02:51.071495274+00:00 TRACE Zigbee Motion Sensor JG Setup driver zigbee-motion with Capability handlers:
default_handlers:
refresh:
refresh
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
refresh:
refresh
child_dispatchers:
2022-05-01T12:02:51.086727608+00:00 TRACE Zigbee Motion Sensor JG Setup driver zigbee-motion with Zigbee handlers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
ZdoHandler
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
2022-05-01T12:02:51.138449274+00:00 TRACE Zigbee Motion Sensor JG Zigbee Device: 0835ef81-3875-45d7-aff0-97cfc52535f3
2022-05-01T12:02:51.146055608+00:00 TRACE Zigbee Motion Sensor JG Received event with handler _resync
2022-05-01T12:02:51.151914941+00:00 TRACE Zigbee Motion Sensor JG Received event with handler environment_info
2022-05-01T12:02:51.163854608+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T12:02:51.171358274+00:00 TRACE Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received unhandled lifecycle event: init
2022-05-01T12:02:51.177889274+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T12:02:51.184588941+00:00 TRACE Zigbee Motion Sensor JG Received event with handler environment_info
2022-05-01T12:02:51.189925608+00:00 DEBUG Zigbee Motion Sensor JG Z-Wave hub node ID environment changed.
2022-05-01T12:02:51.197995274+00:00 TRACE Zigbee Motion Sensor JG Received event with handler driver_lifecycle
2022-05-01T12:02:51.205482941+00:00 TRACE Zigbee Motion Sensor JG Received event with handler device_lifecycle
2022-05-01T12:02:51.211289608+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received lifecycle event: added
2022-05-01T12:02:51.220047274+00:00 TRACE Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received unhandled lifecycle event: added
2022-05-01T12:02:51.225548608+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T12:02:51.231786941+00:00 TRACE Zigbee Motion Sensor JG Received event with handler device_lifecycle
2022-05-01T12:02:51.238167274+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received lifecycle event: driverSwitched
2022-05-01T12:02:51.246501941+00:00 TRACE Zigbee Motion Sensor JG Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-05-01T12:02:51.252203941+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T12:02:51.268083274+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T12:02:51.592868941+00:00 TRACE Zigbee Motion Sensor JG Received event with handler device_lifecycle
2022-05-01T12:02:51.607425608+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received lifecycle event: infoChanged
2022-05-01T12:02:51.621611941+00:00 TRACE Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received unhandled lifecycle event: infoChanged
2022-05-01T12:02:51.627248608+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T12:03:09.403242283+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T12:03:09.555741616+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x6C, rssi: -73, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xE0, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0031, extended_status: 0x00, zone_id: 0x01, delay: 0x0000 > > >
2022-05-01T12:03:09.702047616+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T12:03:09.729227950+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T12:03:09.751641283+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“active”}}
2022-05-01T12:03:09.803178283+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T12:03:21.108640289+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T12:03:33.578784961+00:00 TRACE Zigbee Motion Sensor JG Received event with handler zigbee
2022-05-01T12:03:33.589713295+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xCC76, src_endpoint: 0x23, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x7C, rssi: -69, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0xF4, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0030, extended_status: 0x00, zone_id: 0x01, delay: 0x0000 > > >
2022-05-01T12:03:33.608405295+00:00 TRACE Zigbee Motion Sensor JG Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-05-01T12:03:33.618279961+00:00 INFO Zigbee Motion Sensor JG Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-05-01T12:03:33.625227628+00:00 INFO Zigbee Motion Sensor JG <ZigbeeDevice: 0835ef81-3875-45d7-aff0-97cfc52535f3 [0xCC76] (Office PIR/Temp Edge)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-05-01T12:03:33.647102961+00:00 DEBUG Zigbee Motion Sensor JG Office PIR/Temp Edge device thread event handled
2022-05-01T12:03:51.118537636+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
2022-05-01T12:04:21.117561984+00:00 DEBUG Zigbee Motion Sensor JG driver device thread event handled
With a bit of trial and error this seems to suggest that the device doesn’t support illuminance Measurement, although it does for other platforms. Strange
2022-05-01T12:56:11.064263520+00:00 WARN Zigbee Motion Sensor JG Device does not support cluster 0x0400 not adding configured attribute
2022-05-01T12:56:11.070753853+00:00 INFO Zigbee Motion Sensor JG Device does not support cluster 0x0400 not adding monitored attribute
2022-05-01T12:56:11.080252853+00:00 TRACE Zigbee Motion Sensor JG Zigbee Device: 0835ef81-3875-45d7-aff0-97cfc52535f3
[1]: Identify, Scenes, OnOff [38]: Basic, Identify, TemperatureMeasurement [34]: Basic, Identify, OccupancySensing [35]: Basic, PowerConfiguration, Identify, BasicInput, PollControl, IASZone
2022-05-01T12:56:11.102464187+00:00 TRACE Zigbee Motion Sensor JG Zigbee Device: 1647a172-44d9-4fe4-87d3-c226fe314755
Manufacturer: frient A/S Model: MOSZB-141
[1]: Identify, Scenes, OnOff [40]: Basic, Identify, OccupancySensing [41]: Basic, Identify, OccupancySensing [34]: Basic, Identify, OccupancySensing [35]: Basic, PowerConfiguration, Identify, BasicInput, PollControl, IASZone
that is what it seems, that the MOSZB-140 model has temperature, but it does not have illuminance, at least for smartthings as they say in their advertising.
How illuminance works on other platforms, I don’t know
I just discovered that this device has a peculiarity that I had not seen until now.
It has 4 different endpoints with different clusters and attributes:
- End point (0x1), [1]: Identify (0x0003), Scenes (0x0004), OnOff (0x0006)
- End point (0x22), [34]: Basic (0x0000), Identify (0x003), OccupancySensing (0x0406)
- End point (0x26), [38]: Basic (0x0000), Identify (0x003), TemperatureMeasurement (0x0402)
- End point (0x23), [35]: Basic (0x0000), PowerConfiguration (0x0001), Identify (0x0003), BasicInput (0x000F), PollControl (0x0020), IASZone (0x0500)
I don’t know if this has to do with the fact that smartthings only recognized 4 endpoints, although I thought they had already expanded it. @nayelyz
Illuminance may be at a fifth endpoint that smartthings doesn’t see and that’s why it doesn’t work.
You can try adding to profile the capability switch, which it has on endpoint 1, to see if device responds correctly to the default configuration
In your logs can see that the temperature comes from the endpoint (0x26), IASzone comes from the endpoint (0x23) and battery must comes from end point (0x23) too
Yes, that was included in the latest firmware version.
I think we should rule out a configuration issue first. @Jeff_Gallagher, if your device has different endpoints like @Mariano_Colmenarejo said, you need to map those endpoints accordingly.
https://developer-preview.smartthings.com/docs/edge-device-drivers/zigbee/device.html?highlight=component#multi-component-devices
Note: It would be very helpful if you uploaded your Driver’s code to Github and provide the URL so we can check all the configurations.
