Does anyone know of a uk wired wall socket/light dimmers that can work with ST hub?
Currently on amazon.uk but all i see are lightwave wall sockets which I read is not very user friendly with ST hub.
Appreciate the community’s recommendations pls Thank you!
Fibaro dimmers work with ST, and UK electrics. Are these for use in Singapore?
The reason the UK range is so limited is we have no in-wall Neutral on a lighting circuit usually, whereas the US does - so we can only use dimmers that work without a neutral.
Although Singapore uses the same three pin “type G” plug as the UK, you might find that your lighting is wired differently with a neutral line which means there are many more dimmers you can use.
There’s no in-wall switched three pin plugs that I know of, so you need a plug-in device like the TKB, or ST outlet if you like fire risk.
