Check this out
Wrote this for this exact scenario.
Then just limit your apps to only run when your house is set to one of the “home modes” or “away modes” depending on when you want them to run.
* Auto Home/Away with night modes
* Copyright 2014 Tim Slagle
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
namespace: "tslagle13",
author: "Tim Slagle",
description: "Monitor a set of presence sensors and change mode based on when your home is empty or occupied. Included Night and Day modes for both an occupied and unoccupied house.",
category: "Convenience",
iconUrl: "http://icons.iconarchive.com/icons/icons8/ios7/512/Very-Basic-Home-Filled-icon.png",
iconX2Url: "http://icons.iconarchive.com/icons/icons8/ios7/512/Very-Basic-Home-Filled-icon.png"
preferences {
page(name: "selectPhrases")
page( name:"Settings", title:"Settings", uninstall:true, install:true ) {
section("False alarm threshold (defaults to 10 min)") {
input "falseAlarmThreshold", "decimal", title: "Number of minutes", required: false
section("Zip code (for sunrise/sunset)") {
input "zip", "decimal", required: true
section("Notifications") {
input "sendPushMessage", "enum", title: "Send a push notification when house is empty?", metadata:[values:["Yes","No"]], required:false
input "sendPushMessageHome", "enum", title: "Send a push notification when home is occupied?", metadata:[values:["Yes","No"]], required:false
section(title: "More options", hidden: hideOptionsSection(), hideable: true) {
label title: "Assign a name", required: false
input "days", "enum", title: "Only on certain days of the week", multiple: true, required: false,
options: ["Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"]
input "modes", "mode", title: "Only when mode is", multiple: true, required: false
def selectPhrases() {
def configured = (settings.awayDay && settings.awayNight && settings.homeDay && settings.homeNight)
dynamicPage(name: "selectPhrases", title: "Configure", nextPage:"Settings", uninstall: true) {
section("Who?") {
input "people", "capability.presenceSensor", title: "Monitor These Presences", required: true, multiple: true, refreshAfterSelection:true
def phrases = location.helloHome?.getPhrases()*.label
if (phrases) {
phrases.sort()
section("Run This Phrase When...") {
log.trace phrases
input "awayDay", "enum", title: "Everyone Is Away And It's Day", required: true, options: phrases, refreshAfterSelection:true
input "awayNight", "enum", title: "Everyone Is Away And It's Night", required: true, options: phrases, refreshAfterSelection:true
input "homeDay", "enum", title: "At Least One Person Is Home And It's Day", required: true, options: phrases, refreshAfterSelection:true
input "homeNight", "enum", title: "At Least One Person Is Home And It's Night", required: true, options: phrases, refreshAfterSelection:true
section("Select modes used for each condition. (Needed for better app logic)") {
input "homeModeDay", "mode", title: "Select Mode Used for 'Home Day'", required: true
input "homeModeNight", "mode", title: "Select Mode Used for 'Home Night'", required: true
def installed() {
init()
initialize()
def updated() {
unsubscribe()
initialize()
init()
def init() {
subscribe(people, "presence", presence)
def uninstalled() {
unsubscribe()
def initialize() {
runIn(60, checkSun)
subscribe(location, "sunrise", setSunrise)
subscribe(location, "sunset", setSunset)
def checkSun() {
def zip = settings.zip as String
def sunInfo = getSunriseAndSunset(zipCode: zip)
def current = now()
if (sunInfo.sunrise.time < current && sunInfo.sunset.time > current) {
state.sunMode = "sunrise"
setSunrise()
else {
state.sunMode = "sunset"
setSunset()
log.info("Sunset: ${sunInfo.sunset.time}")
log.info("Sunrise: ${sunInfo.sunrise.time}")
log.info("Current: ${current}")
log.info("sunMode: ${state.sunMode}")
if(current < sunInfo.sunrise.time) {
runIn(((sunInfo.sunrise.time - current) / 1000).toInteger(), setSunrise)
if(current < sunInfo.sunset.time) {
runIn(((sunInfo.sunset.time - current) / 1000).toInteger(), setSunset)
def setSunrise(evt) {
state.sunMode = "sunrise";
changeSunMode(newMode);
sendNotificationEvent("Setting Sunrise Mode")
def setSunset(evt) {
state.sunMode = "sunset";
sendNotificationEvent("Setting Sunset Mode")
def changeSunMode(newMode) {
if(allOk) {
if(everyoneIsAway() && (state.sunMode == "sunrise")) {
log.info("Home is Empty Setting New Away Mode")
def delay = (falseAlarmThreshold != null && falseAlarmThreshold != "") ? falseAlarmThreshold * 60 : 10 * 60
runIn(delay, "setAway")
if(everyoneIsAway() && (state.sunMode == "sunset")) {
else {
log.info("Home is Occupied Setting New Home Mode")
setHome()
def presence(evt) {
if(allOk) {
if(evt.value == "not present") {
log.debug("Checking if everyone is away")
if(everyoneIsAway()) {
log.info("Nobody is home, running away sequence")
else {
def lastTime = state[evt.deviceId]
if (lastTime == null || now() - lastTime >= 1 * 60000) {
log.info("Someone is home, running home sequence")
setHome()
state[evt.deviceId] = now()
def setAway() {
if(state.sunMode == "sunset") {
def message = "Performing \"${awayNight}\" for you as requested."
log.info(message)
sendAway(message)
location.helloHome.execute(settings.awayNight)
else if(state.sunMode == "sunrise") {
def message = "Performing \"${awayDay}\" for you as requested."
log.info(message)
sendAway(message)
location.helloHome.execute(settings.awayDay)
else {
log.debug("Mode is the same, not evaluating")
else {
log.info("Somebody returned home before we set to '${newAwayMode}'")
def setHome() {
log.info("Setting Home Mode!!")
if(anyoneIsHome()) {
if(state.sunMode == "sunset"){
if (location.mode != "${homeModeNight}"){
def message = "Performing \"${homeNight}\" for you as requested."
log.info(message)
sendHome(message)
location.helloHome.execute(settings.homeNight)
if(state.sunMode == "sunrise"){
if (location.mode != "${homeModeDay}"){
def message = "Performing \"${homeDay}\" for you as requested."
log.info(message)
sendHome(message)
location.helloHome.execute(settings.homeDay)
private everyoneIsAway() {
def result = true
if(people.findAll { it?.currentPresence == "present" }) {
result = false
log.debug("everyoneIsAway: ${result}")
return result
private anyoneIsHome() {
def result = false
result = true
log.debug("anyoneIsHome: ${result}")
return result
def sendAway(msg) {
if(sendPushMessage != "No") {
log.debug("Sending push message")
sendPush(msg)
log.debug(msg)
def sendHome(msg) {
if(sendPushMessageHome != "No") {
sendPush(msg)
log.debug(msg)
private getAllOk() {
modeOk && daysOk && timeOk
private getModeOk() {
def result = !modes || modes.contains(location.mode)
log.trace "modeOk = $result"
result
private getDaysOk() {
def result = true
if (days) {
def df = new java.text.SimpleDateFormat("EEEE")
if (location.timeZone) {
df.setTimeZone(location.timeZone)
else {
df.setTimeZone(TimeZone.getTimeZone("America/New_York"))
def day = df.format(new Date())
result = days.contains(day)
log.trace "daysOk = $result"
result
private getTimeOk() {
def result = true
if (starting && ending) {
def currTime = now()
def start = timeToday(starting).time
def stop = timeToday(ending).time
result = start < stop ? currTime >= start && currTime <= stop : currTime <= stop || currTime >= start
log.trace "timeOk = $result"
result
private hhmm(time, fmt = "h:mm a")
def t = timeToday(time, location.timeZone)
def f = new java.text.SimpleDateFormat(fmt)
f.setTimeZone(location.timeZone ?: timeZone(time))
f.format(t)
private getTimeIntervalLabel()
(starting && ending) ? hhmm(starting) + "-" + hhmm(ending, "h:mm a z") : ""
private hideOptionsSection() {
(starting || ending || days || modes) ? false : true
