Virtual 3 way switch
See above. This is just a matter of tying the load line coming off the switch to the hot line that’s feeding the switch. This will make the outlet just like any other outlet in your house by bypassing the switch altogether.
I think Ron’s and my solution is the same.
  1. replace your switched outlet with a new (dumb) one, capping the wire coming from the switch. This will make it always on
  2. replace your wall switch with a Zooz or Innovelli switch (doesn’t require an add-on) and don’t Connect anything to the load. Only line, neutral and ground. Cap the load wire going to the switch.
  3. replace the outlets you wants to control with z-wave versions.
  4. setup Smart lighting rule to mirror outlets based on wall switch.
