Just upgraded to a v2 hub so i re-added all the devices (70+) - very painful. I’ve added the Harmony device but it can’t find any of the hubs that were working well in the v1 hub before I upgraded - any advice please?
try removing ST device from Your Harmony setup then add later
Solved it. It was that you can no longer authenticate the Harmony using a Google+ login (which always used to work) so I had reset the pwd and continued trying to authenticate using just the email and pwd.
Only after I changed to a new email address that wasn’t previously used via the G+ login would it then work.
Hooray!
