Anyway you guys able to set display always on without a touch? At least current temp display would have been awesome.
Got this reply from their support.
In order for the display on the Pearl to remain lit you will need to have a common wire (C terminal) present at the thermostat.
Hi guys,
i got this thermostat working with smartthings, but UI
those sliders is pissing me off(so mad)
really hard to set a temperature using sliders.
Does anyone know if thereās a custom handler that can be modified to use buttons?
Iām sure thereās a custom handler someplace, but if you use ActionTiles there are simple +/- buttons. I know thisās doesnāt help you for the standard ST app, but it is a work aroundā¦
@Rigging65
i was looking at this thread Centralite HA Thermostat
but itās for HA Thermostat,
if you look at the picture some one posted
they have up/down arrows(buttons) next to temp.
was hoping implement to Pearl-touchscreen thermostat.
Or someone already did?
Finally, bite a bullet and changed Device handler to somewhat match Centralite HA thermostat,
at least i have a arrows.
for some reason, iphone and android have different formatting, and not sure how to fix it,
but if anyone interested, i can share my code.
This is Before on Android:
After:
This now suddenly appeared as arrow to increase/decrease temperature which is much better. I did not have to manually update anything. Its nice now with each click temp can be changed.
which model do you have anyway can you upload a picture?
Thanx.
Thanks Raj,
i got update Yesterday as well.
Looks good, except i left mine with my custom UI.
They replaced sliders.
Is there a DTH for these things? I bought one a while back and was never able to get it to connect.
You should be able to just use the Centralite thermostat DTH. I got one for Christmas and thatās what Iāve been using since day 1 and itās worked like a charm. Are you able to connect it and just having issues with the DTH or havenāt been able to connect it?
Would you by chance have a link to the DTH? I have been reading through the threads and canāt seem to find the code for it.
Itās already in smartthings. You donāt have to add your own DTH.
I must be missing something. When I attempt to add it using the ST App, there is no Centralite Thermostat available in the menu.
Well you can go here and get the code thatās official from smartthings. It should automatically be available for you to use, not sure why youāre not seeing it though. Iāve double checked to make sure i didnāt add it myself and itās not a self published dth but itās not.
Thank you so much. Iāve been ripping my hair out looking for that. For some reason the only options I am given under thermostats are 2Gig, ecobee, Fidure, Honeywell, Leviton and Zen. Canāt wait to finally get this thing installed.
Anyone know what this error is when attempting to install the DTH?
Org.springframework.security.access.AccessDeniedException: Run Locally Permission not allowed for DeviceType: f1746ae6-3eb1-4af7-89b7-3ff18bac1183
I agree with Robert. You should not need any additional DTH besides the one that comes built in with smarththings app. I just installed one yesterday and it connected fine without any issue. Go to āadd a thingā on ST app, but donāt hit āAdd device manuallyā button. let ST discover the device itself. If you still canāt see it, then either your thermostat is faulty or you have not activated programming mode 12 properly on the thermostat. Turning on the discover network mode on thermostat is a little tricky though.
I will give it another go. May have to exchange it for a replacement. Thank you both for the feedback.
