I searched the forums on the subjects, but have not found a solution, so here it goes.
I replaced most of my X10 switches and dimmers with Z-Wave ones, which are more reliable of course. And I enjoy an ability to control them remotely using my iPhone or being able to set up all kind of rules using smart apps, etc. But I still miss traditional remote controls that I used with my X10 setup. Like this one: http://www.amazon.com/X10-HR12A-PalmPad-Remote-Control/dp/B00022OCC8/. I have a few of those in my house. They are simple, reliable and the batteries last forever. Not to mention they’re dirt cheap (< $10 in eBay). It would be super cool if I could use those to control SmartThings. Then I wouldn’t have to carry my iPhone with me all the time, reach into my pocket, start an app, etc…
Then, I also have a dozen of X10 EagleEye motion sensors like these: http://www.amazon.com/X10-MS16A-Active-Eye-Motion-Sensor/dp/B000NJBRNW/ installed around the house, both indoors and outdoors. They also work great and cost 1/3 of a typical Z-Wave motion sensor. I’d hate to spend over $500 to replace all EagleEyes with new sensors.
I am interested in this. I too am in the process of slowly doing away with X-10 and upgrade to Z-wave but I also have a bunch of X-10 devices. Especially the motion sensors. I would love if someone found a way to make this do-able.
In the meantime, are you just controlling the X-10 with the remote or do you use software?
I’m using software to control the ST Z-Wave modules in my house with my X10 remotes/motion sensors. I have an X10CM11a two way control module and a Linux PC running the free ppower software. Every time I swap out an X10 device with a Z-Wave I add that X10 modules ID as a macro in the ppower software. Then with the help of the web API the macro hits a URL for turning the device ON or OFF. Works very reliably although there can be a second or two delay at times.
So if I were to replace an X10 module with the ID A1 here is a mocked up example of what my ppower.conf might look like:
ALIAS A1 SmartThings1
MACRO (SmartThings1:ON) {
RUN "curl https://graph.api.smartthings.com/api/smartapps/installations/00000000-0000-0000-0000-0000000000/switches/[ID]/on?access_token=[ACCESS TOKEN]"
MACRO (SmartThings1:OFF) }
RUN "curl https://graph.api.smartthings.com/api/smartapps/installations/00000000-0000-0000-0000-0000000000/switches/[ID]/off?access_token=[ACCESS TOKEN]"
Curl is a simple command line browser of sorts that can access URLs. So when I send an A1 on the X10 network the computer with the CM11A module sees it, runs the curl program to access the URL and the light turns on/off. I used the API tutorial to figure out what the links were to turn my devices on/off and generate the appropriate authentication etc. (http://build.smartthings.com/blog/tutorial-creating-a-custom-rest-smartapp-endpoint/) I’m using Linux and ppower but there’s no reason this wouldn’t work with any software package that supported macros.
