I’ve got the following device code which (appears) to work, basically to return commands interpreted from an IR reciever. Currently, it’s hard-coded to just return the color of the tivo button pressed, once I get that working I can generalize it some more. The arduino shield (i think) sends commands in the format “signalcommand: [color]”
The problem is, I can’t tell if my code to interpret these is working because I can’t use it as a virtual device. I was previously able to create one, but the recent ide changes make one created by default, and it doesn’t seem to be registering min.
Here’s the device code (device is called IRShield):
metadata {
// Simulator metadata
simulator {
// status messages
status “yellow”: "signalcommand: yellow"
status “blue”: "signalcommand: blue"
status “red”: "signalcommand: red"
status “green”: "signalcommand: green"
status “none”: “signalcommand: none”
// UI tile definitions
tiles {
standardTile(“shield”, “device.shield”, width: 2, height: 2) {
state “default”, icon:“st.shields.shields.arduino”, backgroundColor:"#ffffff"
main "shield"
details “shield”
// Parse incoming device messages to generate events
def result
if (description?.startsWith("signalcommand: ")) {
def raw = description - "signalcommand: "
result = createEvent(
value: raw
log.debug "Parse returned ${result?.descriptionText}"
return result
My app code is:
preferences {
section(“Reciver Name:”) {
input “irreciever”, “device.IRShield”, title: “What Reciever?”
section(“Yellow does…”) {
input “yellowswitch”, “capability.switch” // need to make these not just switches
section(“Blue does…”) {
input “blueswitch”, “capability.switch”
section(“Red does…”) {
input “redswitch”, “capability.switch”
section(“Green does…”) {
input “greenswitch”, “capability.switch”
def installed()
//subscribe(irreciever.signalcommand)
//subscribe(motionSensors, “motion.active”, motionActive) i think this is 'item, thing it can say, thing to call
subscribe(irreciever, “signalcommand”, signalHandler)
subscribe(yellowswitch.switch)
subscribe(blueswitch.switch)
subscribe(redswitch.switch)
subscribe(greenswitch.switch)
def updated()
unsubscribe()
subscribe(irreciever, “signalcommand”, signalCommand)
def signalHandler(evt) { // this needs to be named properly and i believe it is the problem
//def infaredcommand = irreciever.signalcommand as String
log.debug "LOOK"
def infaredcommand = evt.value
switch (infaredcommand)
case “yellow”:
yellowswitch.toggle()
break
case “blue”:
blueswitch.toggle()
break
case “red”:
redswitch.toggle()
break
case “green”:
greenswitch.toggle()
break
default:
log.debug "unknown command or null command"
break
Is this going to work? Am I making any obvious mistakes? It didn’t seem to be working before the ide change and right now I can’t really test it with a virtual device.
