Is it possible to use the SmartApps name as a variable for logs? Also, Is it possible to use the SmartApp name assigned to it by the user?
- bump -
Did you try app.label
or app.name
@realsol or jk it is. But wouldn’t you want to differentiate using some sort of preference for multiple installs rather than the name? I guess it depends what you are doing.
@urman, Actually I am using app.label which returns my app name when I installed it. Seems to be working pretty good.
Oh… You can help. Put some heat on the new ‘Documentation’ person.
… and finish up the Harmony Integration …
