I have purchased the V2 but have not installed it yet, I am wondering if I can use both hubs in my home. My house is rather larger and the zigbee devices are hard to get coverage from the Hub. So I’m thinking of using both hubs. Only problem is smartapps on one hub cannot see the devices linked to the other hub. Can someone come up with a smartapp to bridge the two hubs?
At the present time there is no way to link the two together. You can define each one as a separate location and use them both in your home but they cannot control the same devices or relay for each other.
