UK and US version are different Z-wave frequency.
At the moment, i do not use any Z-wave device. All my devices using Zigbee.
Nobody will find out as the range for z-wave device is quite limited.
The only problem of buying US hub is that, you will have difficulties in finding the right z-wave switch and plug later, as the US switches and plug only support 110 V, and it will blow when use in Malaysia.
Hereās my plan for my homestay,
-buy Schlage Connect (the best lock so far, All i need it remote change password and it gets the job done.)
-place SmartThings near the door (less than 3m away)
-get a voltage coverter, around RM25 in Pudu.
Other than that, I will be using ZigBee for motion/light sensor.
I would love to get a ZigBee lock (Yale or Kwikset), but the support from community & price range aināt as good as Schlage Connect.
Why donāt you get an UK version?
Iām using UK version without any issues at the moment.
Furthermore I think most of z-wave device in Malaysia using UK frequency.
it doesnāt compatible with Schlage Connect which is using 908.42MHz.
For the hub, donāt need voltage converter
Anyone manage to pair with Zigbee Switch in malaysia like Xiaomi Aqara ?
Yes, I have Xiaomi temperature, contact sensor, aqara switches, motion sensor managed by smartthings hub v2
Hi Kelvin, nice to know that, i am interested in Aqara Wall Switch too , do you mind to share how you manage to do connect your hub with the Xiaomi Aqara Switches
Thanks Kelvin, i will refer to the link
Iām helping someone in malaysia setup a smartthings hub with several motion sensors.
Where can I buy the hub in malaysia?
If I buy it in US can most things work beside the power adapter and zwave devices?
If someone in malyasia using US smartthings hub please comment pros and cons?
thanks
Iām using UK version which bought from UK
I think it is available in Malaysia officially due to SIRIM
Where do you buy it in malaysia and how much?
I bought it from amazon UK in 2016
If not mistaken, about 850MYR
Iām using the US version currently in msia, get from Amazon us, cheaper also
Ok. Do you have issues using US version of hub in Malaysia? You canāt use zwave unless you buy from US too. I suspect SMS does not work in webcore.
Also can you get zigbee motion sensors in Malaysia?
No issue to use in msia. Depending on what you want, donāt get switches or anything related to electric from US, their Voltage is different.
I get most of my things from factory direct
Do you need a power adapter to convert the voltages? Given youāre using a US hub
