I’m new to smartthings. With IFTTT i used webhooks to talk to another service to set light color at different times to basically create a timeout sequence for my child. It’s using 5 IFTTT webhooks. With IFTTT’s decision to limit the the number of applets you can create, I’m looking to see if i can set this up elsewhere.
Basically I’m hoping when the voice command is issued, lamp 1 turns red, waits 90 seconds, and then lamp 1 turns yellow, waits 90 seconds, lamp 1 turns green, wait 5 seconds and then the whole room would change back to the normal scene where all lights are white. When i try to setup a scene, i can only select lamp 1 once. Is this possible another way? Or will this not work as i’m describing?
