I use three main systems for my security at home:
*Smartthings Hub with one Smartthings multi sensor at one door
*IRIS by Lowes Hub with several door sensors, keypad, and a few other things
*ARLO hub, camera, and siren
There are many reasons why I use both Smartthings and IRIS but I dont want to go into too much detail.
This question I have is instead of using TWO sensors at each door and window (open and close sensors) can I just use ONE that can be monitored by BOTH the IRIS smarthome hub AND the Smartthings hub?
I have paired the open close IRIS sensors which are clearly supported with Smartthings in the Smartthings app and they work and they also work when paired with the IRIS smarthome hub but I can not do them BOTH which is what I wish to do have ONE single sensor work with both hubs,.
Is this possible?
Its seems that you can only pair an open/close sensor with ONE hub at a time but is there some kind off workaround to this?
P.S. if I need one sensor for each hub I will be needing a lot to cover all my windows and doors so does anyone have a link or suggestion for the cheapest reliable open-close senors to work with Smartthings and/or IRIS by Lowes hub?
