Does anyone know of a USB PowerBank that can send battery % to ST or IFTTT?
What I’m specifically looking at doing is using it to power a Raspberry Pi 4 to make it easy to wall mount. I then want to be able to show the remaining battery % via Action Tiles or at least have ST or IFTTT trigger a notification when it gets to a certain %
I’m just trying to avoid needing to power the Raspberry Pi permanently.
You’re not going to find any powerbank that is going to be able to power an RPi for more than a few hours. If you are going to mount it on the wall, how do you plan on charging the battery? You are going to want to run power for it. There is just no way around it.
Also, I would advise using a tablet like the amazon fire tablet 10 rather than an RPi. You are going to spend less money and have something that is much smaller, easier to charge and easier to mount on the wall.
