I’m doing something wrong. I added a new location for my new V3, but my hub is not connecting to it.
Thinking I’ve setup something wrong, gone back into groovy to delete all the smartapps and devices from the old location. So in groovy that old location looks empty, but I can’t delete that location.
I’m basically trying to default my account at this point to reinstall the new hub and my old devices. Any suggestions?
Make sure the location you are trying to delete is not the default location in the IDE.
Log in to the IDE. Go to My Locations. Select the location you are trying to delete. Select the Edit button. Second field is default location. Should be false, if it is true you will not be able to delete that location. If you only have one location you will not be able to change it from true.
