Updating Temp Sensor Device
(JukeBox) #1
Two questions for the community:
  1. What is the best way to do input validation on incoming data from GET APIs etc? I’ve got a very rudimentary way at present which I’m sure is very clunky…
  2. I’ve created a new Temperature Sensor and would like to update it based on the temperature and humidity values received by the API (sounds simple enough?)
Error Messages:
error java.lang.NullPointerException: Cannot invoke method setTemperature() on null object @ line 68
error error: groovy.lang.MissingMethodException: No signature of method: cript14342832688371907786814.$() is applicable for argument types: script14342832688371907786814$_makeJSONWeatherRequest_closure2_closure4) values: script14342832688371907786814$_makeJSONWeatherRequest_closure2_closure4@16a09c76] Possible solutions: is(java.lang.Object), now(), url(), run(), any(), app(java.util.Map)
Code:
def makeJSONWeatherRequest() {
	//variables
    def vtemp = 0.0
    def vhumi = 0
    def params = [
        uri:  'http://host.com',
        path: '/api/',
        contentType: 'application/json',
        query: [device:'1', token: 'xxx']
    try {
        httpGet(params) {resp ->
            log.debug "raw response data: ${resp.data}"
            vtemp = ${resp.data.temp}
            vhumi = ${resp.data.humi}
    } catch (e) {
        log.error "error: $e"
 //silly way of doing input validation?
    if (vtemp.toString().isDouble() && vhumi.toString().isInteger()) {
    	if (vtemp.toString().length() <= 7 && vhumi.toString().length() <= 3) {
        	log.debug "Correct data recieved."
            //Update temp
            //settings.target.parse("temperature: ${vtemp}")
            //settings.target.parse("humidity: ${vhumi}")
           target.setTemperature(vtemp)
	} else {
    	    log.error "error: dataset was incomplete or invalid."
            System.exit(0)
Really do appreciate the help! I’m trying to translate my ancient perl skills into groovy! oh, how things have changed.
Cheers,
JB.
(sidjohn1) #2
I’m not sure if this line will work. You set vtemp and vhumi to strings. i don’t think they can be a string and a double or a interger as well.
To my knowledge string = text, integer = whole number, double = decimal places. You might want to kill the .toString and see if that works better.
(John S) #3
target isn’t set anywhere in this method, so it’s null. Unless I missed something. That’s exactly what the error message is saying, at least.
Did you mean to use settings.target?
(John S) #4
Separate question :smile:
Everything comes in as a string. Groovy mostly feels like java for string processing, and also has the same try/catch things
so, doing something like this should work
def dvtemp = -1.0
def ivhumi = -1
try {
  dvtemp = vtemp.toDouble();
  ivhumi = vhumi.toInteger();
  // still here? seems plausible. validate dvtemp and ivhumi to be within whatever range
  // you accept, and if so, call the set() methods
  if ((dvtemp > 30.0) && (dvtemp < 90.0)) settings.target.setTemperature(dvtemp)
} catch (e) {
  // invalid data passed in. Ignore it
  // DON'T exit here
No need to exit, your SmartApp only runs when its needed
(JukeBox) #5
Thanks John and Sid. Appreciate the help, and I have been able to tighten up the error checking. However, I’m still getting the following error:
error: groovy.lang.MissingMethodException: No signature of method: script1434322929919539404578.$() is applicable for argument types: (script1434322929919539404578$_makeJSONWeatherRequest_closure2_closure4) values: [script1434322929919539404578$_makeJSONWeatherRequest_closure2_closure4@6565730]
Which seems to relate to this code:
def vtemp = 0.0
def vhumi = 0
Is this an incorrect process for setting these values?
Thanks,
JB.
(JukeBox) #6
OK, would seem like you just use resp.data.humi minus the ${}
(JukeBox) #7
The next piece in the puzzle:
settings.target.setTemperature(vtemp)
Error:
error: dataset was incomplete or invalid. java.lang.IllegalArgumentException: Command 'setTemperature' is not supported. Supported commands: []
(John S) #8
What is settings.target? Where is that initialized? It’s telling you that whatever that is, it doesn’t have any commands at all.
(JukeBox) #9
Hi John,
target is the device (that I created manually) that I am trying to set the temp/humi on.
I initialise it with the following:
preferences {
    section("Choose a target virtual temperature tile... "){
        input "target", "capability.temperatureMeasurement", title: "Tile"
(JukeBox) #10
It would seem that you can’t set the temperature (or humidity) on a Thermostat Sensor manually created in the IDE… Not sure what is missing? Any clues?
(John S) #11
I made one with setters for you from the template - the templates don’t have setters
(John S) #12
Using custom device types is pretty much the same as Smart Apps. Here is a great writeup if you don’t want to slog through the docs
For this, save this as a new device type, and then edit the device you made to use this new device type, and you should be good to go
(JukeBox) #13
Hi John,
Thanks very much for your help. So, lesson: I was trying to update the default device which couldn’t be updated.
I’ve been able to now get the SmartApp to work with the Custom Device. The data is flowing, I need to make some tweaks to the device code as I’m using C not F.
Last question on this topic: where do you get the code for the Devices? You used the Temperature Sensor template - are they all available?
Thanks again for your help!
(John S) #14
See the link in my post above :smile:
tl;dr version:
Click Create New Device Type
Select From Template
Scroll down list of template device types - if you see the device type you want to modify, choose it and modify away!
(Casper) #15
Hi, I’m looking for the exact same thing, could you share the code on the device type that pull data from an API?
