Is there a way to use this without having to delete all the hue lights I currently have setup? I have some pretty extensive automations already created and it would be a huge pain to have to redo them all. If there is a way around it I would be all ears!
im afraid not
Good news thanks to @foz_turner I have been able to fix the install problem that some people have been having, the app will be updated on github tomorrow
Do you have any hair left?
Does this go all the way back to when you took this SA over? Big props for sticking with it and fixing it. Almost thinking it would have been quicker if you had rebuilt it from the ground up, your way
HUE B SMART UPDATE 1.5
PLEASE TEST MY CODE I havenât released the fix for the install to the master branch yet as I donât want to break everyoneâs Hue B Smart setup, So I have made a 1.5 branch on github (link is below) for any one that wants to test for me, Please note My house is currently working with 2 Hue bridges installed, When I get home I will test adding my test hub.
Updated Version 1.5 TESTING https://github.com/tmleafs/Hue_B_Smart/tree/tmleafs-1.5
1.5 Fixed Install issue for some users
1.5 Removed Non-Working Quick Fixes from App & DHâs
1.5 Removed Non-Working Schedules from App & DHâs
1.5 Added Light Capability to all Light DHâs
Thanks to @foz_turner for allowing me IDE access to be able to fix the install issue
NOTE: It is not required, nor necessary to donate to use this SmartApp. This is a free open source software, That I have taken over development as no one else did. But if you feel like it, you can donate here.
This is lovely and so much better than the built in SmartLights app. Can actually have lights turn on / off in sync now! Edit: I donât suppose you have venmo or square cash for receiving donations ? PayPal and I donât get along
Those both seem to be US only services
After several failed tries and reverting back to stock HUE app because it was impossible to find my bridge in âHue B Smartâ app (due to âpreviously found bridgeâ error in logs), I tried the 1.5 branch and this finally works for me too. Thanks a lot, as this is much easier and efficient way of working with lights automatisations.
I have a âhub v2, UK customerâ hardware, currently on 000.019.00020 firmware.
HUE B SMART UPDATE 1.6
Updated Version 1.6 TESTING https://github.com/tmleafs/Hue_B_Smart/tree/tmleafs-1.5
- You can now turn off debugging for the SmartApp
- The IDE Logs have been made more pretty for when they are on (Now uses trace, info, warn and error)
This is currently in the 1.5 branch, I plan to do some testing tonight and hopefully this will merge this into the master
Please advise when stable
its stable the only thing that needs to be tested is adding another bridge with a bridge already installed in Hue B Smart this only affects a small amount of users, I have 2 due to the old limitation of the amount of hue dimmers you could have per bridge & and third for testing this app. But fresh installs are fine
What about upgrading from 1.4? Havenât had any issues with my 1 bridge thus far
I have three bridges, but they are all already on hue b smart. Should I wait to upgrade? Or should it be fine?
I will be updating the master before midnight GMT
Master updated to 1.6
Updated Version 1.5 & 1.6 28th January 2018
- Fixed Install issue for some users
- Removed Non-Working Quick Fixes from App & DHâs
- Removed Non-Working Schedules from App & DHâs
- Added Light Capability to all Light DHâs
Hi
I just tried to link my bridge but still geting error:
> 18:53:48: error grails.validation.ValidationException: Validation Error(s) occurred during save():
> - Field error in object 'physicalgraph.device.Device' on field 'deviceNetworkId': rejected value [00178849B6FD]; codes [physicalgraph.device.Device.deviceNetworkId.unique.error.physicalgraph.device.Device.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.error.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.error.java.lang.String,physicalgraph.device.Device.deviceNetworkId.unique.error,device.deviceNetworkId.unique.error.physicalgraph.device.Device.deviceNetworkId,device.deviceNetworkId.unique.error.deviceNetworkId,device.deviceNetworkId.unique.error.java.lang.String,device.deviceNetworkId.unique.error,physicalgraph.device.Device.deviceNetworkId.unique.physicalgraph.device.Device.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.java.lang.String,physicalgraph.device.Device.deviceNetworkId.unique,device.deviceNetworkId.unique.physicalgraph.device.Device.deviceNetworkId,device.deviceNetworkId.unique.deviceNetworkId,device.deviceNetworkId.unique.java.lang.String,device.deviceNetworkId.unique,unique.physicalgraph.device.Device.deviceNetworkId,unique.deviceNetworkId,unique.java.lang.String,unique]; arguments [deviceNetworkId,class physicalgraph.device.Device,00178849B6FD]; default message [{0} must be unique]
Any ideas whats Iâm doing wrong?
Never seen anything like that before! Have your removed all official hue devices and app from ST?
If you have can you post more of the log
Thanks for help, I did not removed official app, after removing it everything is working fine
good to hear enjoy
Hey - the âlast updateâ in the code that I have is 11/28/2017. Is that accurate?
SmartApp:
- Last Updated : 11/28/2017
- SmartApp version: 2.0.3*
- Door device version: 2.1.2*
- Door-no-sensor device version: 1.1.1*
- Light device version: 1.0.1*
