Need to.remove any official hue devices and apps currently installed in smartthings
Got it thank you. For some reason Hue Hub didnāt āremoveā the first time. Tried again now everything works
do we remove hue devices/bridge from smartthings app only. should we remove hue bulbs from hue app too?
Just from ST
Thank you for this, it makes things SO much easier
This looks great! I am having issues getting this setup though. Whenever i go into the app and discover the bridge I push the link button and it crashes and goes back to smartthings. I have checked in IDE and i have no Hue parts anywhere. I also readded Hue to remove each bulb and then the hub last.
Hi
I finally succeeded and installed the Hue B Smart app
copies raw code from here https://github.com/tmleafs/Hue_B_Smart/blob/master/smartapps/info-fiend/hue-b-smart.src/hue-b-smart.groovy
when I launch it, I see the bridge with ip address, when I click on it it says please press the link button your hue bridge, I press the hue button but nothing happens, in fact the app goes back to previous screen. Any thought what might be causing that?
Logs below. few of them have warn, one has error
Thx
11:19:31 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:19:28 PM: info Button Pressed - Link Done - Save Username
11:19:28 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:19:28 PM: info IP Address is 192.168.1.21:80
11:19:28 PM: info MAC Address is 0017884EE307
11:19:28 PM: info Sending Developer Request
11:19:24 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:19:21 PM: info Button Pressed - Link Done - Save Username
11:19:21 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:19:21 PM: info IP Address is 192.168.1.21:80
11:19:21 PM: info MAC Address is 0017884EE307
11:19:21 PM: info Sending Developer Request
11:19:17 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:19:14 PM: info Button Pressed - Link Done - Save Username
11:19:14 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:19:14 PM: info IP Address is 192.168.1.21:80
11:19:14 PM: info MAC Address is 0017884EE307
11:19:14 PM: info Sending Developer Request
11:19:11 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:19:08 PM: info Button Pressed - Link Done - Save Username
11:19:08 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:19:08 PM: info IP Address is 192.168.1.21:80
11:19:08 PM: info MAC Address is 0017884EE307
11:19:08 PM: info Sending Developer Request
11:19:04 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:19:02 PM: info Button Pressed - Link Done - Save Username
11:19:01 PM: debug linkButton [id:, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, mac:0017884EE307, ip:192.168.1.21, linkingBridge:true]
11:19:01 PM: info IP Address is 192.168.1.21:80
11:19:01 PM: info MAC Address is 0017884EE307
11:19:01 PM: info Sending Developer Request
11:18:46 PM: trace Previously found bridge discovered
11:18:46 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:18:46 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:18:45 PM: trace Previously found bridge discovered
11:18:45 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:18:45 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:18:44 PM: info Sending bridge discovery
11:18:44 PM: info Doing Hue Device Sync!
11:17:31 PM: trace Previously found bridge discovered
11:17:31 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:31 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:30 PM: trace Previously found bridge discovered
11:17:30 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:30 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:29 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:29 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:29 PM: warn Bridge Discovery Sent - Version is 1.71
11:17:29 PM: info Sending bridge discovery
11:17:27 PM: trace Previously found bridge discovered
11:17:27 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:27 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:27 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:27 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:26 PM: trace Previously found bridge discovered
11:17:26 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:26 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:26 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:26 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:26 PM: warn Bridge Discovery Sent - Version is 1.71
11:17:25 PM: info Sending bridge discovery
11:17:23 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:23 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:22 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:22 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:22 PM: trace Previously found bridge discovered
11:17:22 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:22 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:21 PM: trace Previously found bridge discovered
11:17:21 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:21 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:20 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:20 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:20 PM: warn Bridge Discovery Sent - Version is 1.71
11:17:20 PM: info Sending bridge discovery
11:17:19 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:19 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:18 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:18 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:18 PM: trace Previously found bridge discovered
11:17:18 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:18 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:17 PM: trace Previously found bridge discovered
11:17:17 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:17 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:17 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:17 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:16 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:16 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:16 PM: warn Bridge Discovery Sent - Version is 1.71
11:17:16 PM: info Sending bridge discovery
11:17:15 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:15 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:15 PM: trace Previously found bridge discovered
11:17:15 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:15 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:14 PM: trace Previously found bridge discovered
11:17:14 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:14 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:13 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:13 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:13 PM: warn Bridge Discovery Sent - Version is 1.71
11:17:13 PM: info Sending bridge discovery
11:17:12 PM: trace Previously found bridge discovered
11:17:12 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:12 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:12 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:12 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:10 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:10 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:09 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:09 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:09 PM: warn Bridge Discovery Sent - Version is 1.71
11:17:09 PM: info Sending bridge discovery
11:17:07 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:07 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:06 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:06 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:05 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:05 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:05 PM: trace Previously found bridge discovered
11:17:05 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:05 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:03 PM: trace Previously found bridge discovered
11:17:03 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:03 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:03 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:03 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:02 PM: trace Previously found bridge discovered
11:17:02 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:02 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:17:03 PM: warn Bridge Discovery Sent - Version is 1.71
11:17:03 PM: info Sending bridge discovery
11:17:02 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:17:02 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:17:00 PM: trace Previously found bridge discovered
11:17:00 PM: info Discovered bridge 0017884EE307 (192.168.1.21)
11:17:00 PM: trace Discovery Response is [devicetype:04, mac:0017884EE307, networkAddress:C0A80115, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d21e8e1f-088b-47d0-8202-58bd6e2722e6]
11:16:59 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:16:59 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:16:59 PM: warn Bridge Discovery Sent - Version is 1.71
11:16:59 PM: info Sending bridge discovery
11:16:56 PM: debug linkButton [id:, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, mac:0017884EE307, ip:192.168.1.21, linkingBridge:true]
11:16:54 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:16:54 PM: debug Bridges UnLinked IP Address 192.168.1.21
11:16:33 PM: error physicalgraph.app.exception.UnknownDeviceTypeException: Device type āHue B Smart Bridgeā in namespace āinfo_fiendā not found. @line 189 (linkButton)
11:16:33 PM: trace bridge.value.serialNumber = 0017884ee307 *****************
11:16:33 PM: trace state.host = 192.168.1.21:80 ******************
11:16:33 PM: trace state.user = E7iHd4i9qArGUAouQA1hPva33sdLLScKantVbc07 ******************
11:16:33 PM: info Bridge uuid:2f402f80-da50-11e1-9b23-0017884ee307={deviceAddress=0050, devicetype=04, hub=d21e8e1f-088b-47d0-8202-58bd6e2722e6, itemsDiscovered=false, mac=0017884EE307, name=Philips hue (192.168.1.21), networkAddress=C0A80115, serialNumber=0017884ee307, ssdpNTS=null, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-0017884ee307, stringCount=04, verified=true}
11:16:33 PM: trace username E7iHd4i9qArGUAouQA1hPva33sdLLScKantVbc07
11:16:33 PM: trace ssdp uuid:2f402f80-da50-11e1-9b23-0017884ee307
11:16:33 PM: info Bridge linked!
11:16:28 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:16:28 PM: info IP Address is 192.168.1.21:80
11:16:28 PM: info MAC Address is 0017884EE307
11:16:28 PM: info Sending Developer Request
11:16:24 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:16:21 PM: info Button Pressed - Link Done - Save Username
11:16:21 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:16:21 PM: info IP Address is 192.168.1.21:80
11:16:21 PM: info MAC Address is 0017884EE307
11:16:21 PM: info Sending Developer Request
11:16:15 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:16:12 PM: info Button Pressed - Link Done - Save Username
11:16:11 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:16:11 PM: info IP Address is 192.168.1.21:80
11:16:11 PM: info MAC Address is 0017884EE307
11:16:11 PM: info Sending Developer Request
11:16:08 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:16:05 PM: info Button Pressed - Link Done - Save Username
11:16:04 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:16:04 PM: info IP Address is 192.168.1.21:80
11:16:04 PM: info MAC Address is 0017884EE307
11:16:04 PM: info Sending Developer Request
11:16:01 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:15:58 PM: info Button Pressed - Link Done - Save Username
11:15:57 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:15:57 PM: info IP Address is 192.168.1.21:80
11:15:57 PM: info MAC Address is 0017884EE307
11:15:57 PM: info Sending Developer Request
11:15:54 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:15:51 PM: info Button Pressed - Link Done - Save Username
11:15:50 PM: debug linkButton [id:, ip:192.168.1.21, linkingBridge:true, mac:0017884EE307, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307]
11:15:50 PM: info IP Address is 192.168.1.21:80
11:15:50 PM: info MAC Address is 0017884EE307
11:15:50 PM: info Sending Developer Request
11:15:47 PM: debug linkButton [id:, name:linkButton, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017884ee307, mac:0017884EE307, ip:192.168.1.21, linkingBridge:true]
11:15:44 PM: debug Bridges UnLinked MAC Address 0017884EE307
11:15:44 PM: debug Bridges UnLinked IP Address 192.168.1.21
You havent installed any of the device handlers
No I havenāt.
I thought you either install the smart app or device handlers
Can you point what exactly needs to be installed
Appreciate your help really
You need to install all these device handlers
I missed that part. done and working
Now anyway to add everything by one click or we have to add one thing at a time?
Thx
The point of the app is to add scenes and groups plus reduce the amount of devices needed to be in ST
makes sense. I see that rooms (in Hue) are treated as things in the ST hub right? I believe no need to add every single bulb individually as long as we are adding the rooms
Yeah, add the rooms. Then add any of the individual scenes if you want an additional SmartThings thing to activate that scene.
So far so good but Iām having issues with hue scenes
The list is so big most likely because I also have bunch of Hue sensors/dimming switches, so now I see bulb numbers above what I actually have which is confusing.
Nonetheless I tried adding one scene. When clicked push it made the lights turn off instead of activating the scene
Anyway I could clean up the hue Bridge and make it have the right amount of scenes? No way I can remove all the lights and re add them one by one
Renaming the scenes in the Hue app will make adding them in SmartThings easier. I donāt have nearly as many Hue bulbs as you do, only about a dozen in five rooms, but I changed the names of the scenes I wanted to add in SmartThings. So now the Kitchen scenes are all K Bright, K Dim, etc.
very good idea. Iāll rename the scenes I mostly use, then Iāll refresh Hue B mSmart, hopefully thatāll make thing easier
will try as soon as I go home
Itās working
I was hoping I could use the scenes using smart lighting app. I do have iris sensors but the app gives limited option (shades of white, few colors). I saw an option to mirror behavior when I click on it it shows the scenes so I thought that would work but it didnāt, motion sensor doesnāt trigger the scene or not even turn on slights . Apparently mirror behavior does something else that Iām not familiar with
Any other way to achieve what I want?
Thanks you all again
