More errors on the SmartApp.
Logs
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:11:31 PM: infoManage Bridge MAC Address 0017882CA445
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:11:27 PM:debug Bridges Linked MAC Address 0017882CA445
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:11:27 PM:debug Bridges Linked IP Address 10.0.0.133
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:11:17 PM: errorgroovy.lang.MissingPropertyException: No such property: description for class: java.lang.String @line 896 (locationHandler)
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:41 PM: tracePreviously found bridge discovered
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:41 PM: infoDiscovered bridge 0017882CA445 (10.0.0.133)
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:41 PM: traceDiscovery Response is [devicetype:04, mac:0017882CA445, networkAddress:0A000085, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017882ca445, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d9c98b70-dd99-4b50-84b6-5da994f0293b]
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:40 PM: tracePreviously found bridge discovered
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:40 PM: infoDiscovered bridge 0017882CA445 (10.0.0.133)
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:40 PM: traceDiscovery Response is [devicetype:04, mac:0017882CA445, networkAddress:0A000085, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017882ca445, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d9c98b70-dd99-4b50-84b6-5da994f0293b]
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:38 PM: tracePreviously found bridge discovered
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:38 PM: infoDiscovered bridge 0017882CA445 (10.0.0.133)
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:38 PM: traceDiscovery Response is [devicetype:04, mac:0017882CA445, networkAddress:0A000085, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017882ca445, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d9c98b70-dd99-4b50-84b6-5da994f0293b]
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:37 PM: tracePreviously found bridge discovered
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:37 PM: infoDiscovered bridge 0017882CA445 (10.0.0.133)
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:37 PM: traceDiscovery Response is [devicetype:04, mac:0017882CA445, networkAddress:0A000085, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017882ca445, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:d9c98b70-dd99-4b50-84b6-5da994f0293b]
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:35 PM:debug Bridges Linked MAC Address 0017882CA445
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:35 PM:debug Bridges Linked IP Address 10.0.0.133
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:35 PM: warnBridge Discovery Sent - Version is 1.6
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:35 PM: infoSending bridge discovery
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:33 PM: infoManage Bridge DeviceName is Hue Hub
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:33 PM: infoManage Bridge IP Address 10.0.0.133
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:30 PM: infoManage Bridge MAC Address 0017882CA445
7b7e67a9-cee6-4dc4-9a7b-f58dbb512f5e 12:08:30 PM: traceManage Bridge uuid:2f402f80-da50-11e1-9b23-0017882ca445={bulbs={10={id=10, label=Bathroom 3, state={alert=none, bri=100, colormode=hs, ct=359, effect=none, hue=7422, mode=homeautomation, on=false, reachable=true, sat=117, xy=[0.4540, 0.3975]}, type=Extended color light}, 11={id=11, label=Bathroom 1, state={alert=none, bri=100, colormode=hs, ct=359, effect=none, hue=7422, mode=homeautomation, on=false, reachable=true, sat=117, xy=[0.4540, 0.3975]}, type=Extended color light}, 12={id=12, label=Bathroom 4, state={alert=none, bri=100, colormode=hs, ct=359, effect=none, hue=7422, mode=homeautomation, on=false, reachable=true, sat=117, xy=[0.4540, 0.3975]}, type=Extended color light}, 13={id=13, label=Front Door Hue, state={alert=none, bri=203, mode=homeautomation, on=false, reachable=true}, type=Dimmable light}, 14={id=14, label=Office Hue, state={alert=none, bri=200, mode=homeautomation, on=false, reachable=true}, type=Dimmable light}, 15={id=15, label=Living Room Lamp, state={alert=none, bri=230, colormode=hs, ct=325, effect=none, hue=57140, mode=homeautomation, on=false, reachable=true, sat=200, xy=[0.4323, 0.2293]}, type=Extended color light}, 16={id=16, label=Living Room Lamp 2, state={alert=none, bri=230, colormode=hs, ct=325, effect=none, hue=57140, mode=homeautomation, on=false, reachable=true, sat=200, xy=[0.4323, 0.2293]}, type=Extended color light}, 17={id=17, label=K/L Lightstrip, state={alert=none, bri=152, colormode=hs, ct=153, effect=none, hue=41778, mode=homeautomation, on=false, reachable=true, sat=90, xy=[0.3014, 0.3174]}, type=Extended color light}, 18={id=18, label=Bedroom Lamp 2, state={alert=none, bri=165, colormode=xy, ct=236, effect=none, hue=54479, mode=homeautomation, on=false, reachable=true, sat=188, xy=[0.3716, 0.2103]}, type=Extended color light}, 19={id=19, label=Bedroom Lamp 1, state={alert=none, bri=165, colormode=xy, ct=236, effect=none, hue=54479, mode=homeautomation, on=false, reachable=true, sat=188, xy=[0.3716, 0.2103]}, type=Extended color light}, 7={id=7, label=Living Room Soffiā¦[TRUNCATED]
Iāve spoken to another person using this SmartApp and they get the same results
