Contact ST support and ask to have your Zigbee firmware upgraded to at least 1.5.4.
Thanks guys. Asked ST support to push the zigbee firmware and that solved my problem. Great community and great support!
iām still having trouble with my GE lInk Bulbs and thought that it might be a bad set of bulbs and so I when to Staples and brought a Dlink Hub and set one of the GE links bulbs up on the Staples Hub reset my on the Smartthings hub and My Smartthings hub lost control where as the Staples Hub is still going. I really like the Smartthings but I can understand why so much difficult setting up and maintain a light bulb. Iām using channel 14 on Zigbee and my firmware is 1.5.4 and was wondering how to try another Zigbee Channel??? How do i go to another channel??
Unfortunately for the current generation of the smartthings hub, the zigbee channel is set randomly when the hub is manufactured and cannot be changed after that.
Also, a zigbee device can only have one primary controller, so it can connect to SmartThings or Staples Connect, but not both at the same time. (The Hue bridge is different: the bulbs are zigbee, but the bridge is connected via Ethernet. So a Hue bridge can connect to multiple other systems simultaneously.)
@JDRoberts Thanks for the reply and Iām sorry if I mislead but I understand you can only have one primary controller for each Zigbee Bulb. I have 6 all together and was just trying to see if another controller was having the same problem of resetting the GE Links and so far they donāt. I have one of the six bulbs now set up with the Staples Dlink and the rest with smartthings I keep having to resets the one on the smartthing hub. I been using the Staples Hub for the GE link one bulb and the Aeon Powerstrip which they already have set up. I just donāt know why I keep having trouble with the GE bulbs on the Smartthing Hub??? I have to reset them often.
No idea. Some people report this problem, others donāt. It may be local interference, but since we canāt change the ST hub zigbee channel, itās hard to say. Very frustrating, I know.
Occasionally, one of my exterior bulbs will accidentally be turned off/on at the switch. I only use these lights at night and they are activated/deactivated by mode changes. So, after someone accidentally turns the light on, it will stay only until the following morning. Being a porch light, we donāt even notice that itās on unless we are at the front of the house.
Iāve been looking for a SmartApp that will turn the bulb off if itās on for so many minutes or in a certain mode, but havenāt had any luck. SmartThings KNOWS that the light is on if that helpsā¦
Any ideas?
if you make a dashboard shortcut you can āturn it off after a period of timeā
Thank you! (We need an easier UI!)
Shortcut group, or Power Allowance smartapp are both possibilities.
Or
Hey guys,
So I never used the dim rate function until a few weeks ago, but now that I tried it I love it. So my question is with the new Smart Lighting app there is the turn on and set level setting. If you use that, the bulb ignores the dim rate ability and just turns on instantly to the level setting.
I would love to be able to set an on and set level to 50% and still use the slow dim rate. Would something like that be possible? Thanks.
There is in the new Smart Lighting app I believe.
Setting level in Smart Lighting overrides the device type preference of dim rate.
I want to set level and use dim rate. That is my question. =)
oh, dim rate itselfā¦yeah not in there. In fact I havenāt seen it outside my GE Link bulbs but thats all I will use now.
Itās an awesome feature
The Smart Lighting app isnāt ignoring the dim rate ability. Itās simply sending a setLevel() command to the bulb, which the device handler then sends to the bulb with the dim rate parameter (Live Logging confirmed this).
I think what youāre seeing/experiencing is due to how the zigbee level cluster works. When you send a level command the bulb will transition from the current level to the new level using the dim rate sent with the command. When the bulb turns off, it retains its current level so it can return to that level when its turned back on. So what happens is from āoffā the bulb immediately goes to its current level, then transitions to the new level being sent.
Hereās an example:
Bulb is at 99%, then is turned off. Current level stays 99%.
Send setLevel(50) as part of your Smart Lighting app.
Bulb goes immediately to 99%, then dims to 50% using the rate specified.
The closer the current level and your new level are, the more itāll look like it automatically goes to that setting. Thereās also less distinction between light output in the top half, so it may be transitioning, but itās hard to perceive it.
I guess we could add a check in the device handler, that will quickly move the level to 0 before sending a setLevel when the bulb is off.
sorry, youāre right I didnāt check the logs, and I didnāt notice any transition.
I think that would be awesome. The slow dim rate is really a nice effect.
I submitted this tweak to ST via GitHub along with an updated tile layout for the new app. Hopefully they see it and can apply the update quickly.
Any possibility of reporting that a bulb has been manually turned OFF? E.g. If s bulb doesnāt respond to polling/refreshā¦ Set it to OFF?
Thatās been requested many times, but my understanding is that the platform just isnāt designed that way. In some ways, it makes sense, since both zigbee and zwave are mesh networks. Thereās no garuntee that any given node will respond to any given poll.
