If he gets your Transition Time issue dialed in, I may remove everything this weekend and try again now that it looks like all of the major issues have finally been resolved. This all started with you way back when
Thanks for the information, looks like I got job this weekend. Fingers crossed, wife said âlets go back to Wink i like the icon betterâ. Putting racing stripes on a chevy geo doesnât make it fasterâŠ
It does if there are more people behind pushing it and itâs going down hill
Oh, I remember. I am still curious what happened to infofiend?
I donât understand where the - - are coming from it should say âtransitiontime isâ at least
I did not do a research of my devices with the bridge, I only updated the DTH, could that be it?
Are any of you getting the transition time display bug that @jasonrwise77 is getting I canât reproduce it even when adding new bulbs
DO NOT UPDATE TO MY FORK IF YOU HAVE MORE THAN ONE HUB
If you have more than one hub and want to do a fresh install please do but copy everything from live logging while installing and any errors.
I have just broken my two hub setup when moving to my fork today
I can confirm Iâm not getting the transition time display bug. Iâm on IOS though.
@tmleafs That may be the getCommandData() changes. It definitely would cause problems with multiple hubs. The IP and user were not getting initialized on the bridge. The update to getCommandData() gets those from the state of the smart app which will not handle multiple hubs It needs a better fix for the bridge initialation. Sorry. The old code probably worked once the bridge(s) initialized, but the bridge initialization wasnât setting the IP and user.
Yup that is correct
I have managed to fix my setup by modifying the bridge for manual input
Now that I cant break my setup I will work out a fix
One very minor niggle is that if you switch the light on or off with a group, the status of the individual lights remains off or on and vice versa but aside from this is all working extremely well and quickly to all your credit.
Yea it has to wait till the next sync which is every 5 mins so most of the time it will be less. I believe infofriend has solved this in his latest version I will look into it once I have solved the multiple HUB problem
Update I have fixed the updating of individual lights when a group is turned off or on - The reason I removed it was if you didnt have all the bulbs from a group it would error but I have also been able to fix that - Havenât uploaded it to github yet
Hue Bridge Just won a Hue bridge on ebay for ÂŁ20 pounds so will be able to test everything except a fresh install in the future
Disregard. I figured it out. After discovering my bridge I went back to things and added a new thing and then my bridge was there so I saved. Then went back into HBS and the devices were all found. You seriously have to select each bulb, each scene, each everything to add in? Lol omg. Now I need to figure out how all those pieces showing up in thing now work. Gotta love not having any documentation to support everything from day 1.
Anyway thanks again tmLeafs for getting this thing working. Much appreciated.
How many Bulbs, Groups, Scenes do you have?
Out of my 13 Groups I add 10 of them
Out of my 33 bulbs I add only 4
Your really want everything added then go through them all and delete ones you dont need?
I think @infofiend had some personal issues that kept him off this DTH development for about three weeks a month and a half ago. He may be gone this time for awhile.
@tmleafsâThanx so much for stepping in! I have not switched to your branch yet since I havenât needed to add devices to my Hue hub yet. But I was wondering if youâre able to help decipher this error (every five minutesâthe polling interval) in the Bridge DTH log:
8:07:07 AM: error java.lang.ArrayIndexOutOfBoundsException 8:07:07 AM: trace Bridge discovering all items on Hue hub. 8:02:07 AM: error java.lang.ArrayIndexOutOfBoundsException 8:02:07 AM: trace Bridge discovering all items on Hue hub. 7:57:07 AM: error java.lang.ArrayIndexOutOfBoundsException 7:57:07 AM: trace Bridge discovering all items on Hue hub. 7:52:07 AM: error java.lang.ArrayIndexOutOfBoundsException: 1 @ line 1393 7:52:07 AM: trace Bridge discovering all items on Hue hub.
It doesnât point to â@ line 1393â all the time, but maybe once every six to ten times.
Are you running the latest original version?
Thatâs one of the issues with the getCommanData() function. Itâs trying to get a device, but the bridge initialization calls it without a device (no â/â in the id).
