Update to keen vent device type
Here is an update to the keen vent device type…
I found a copy on this forum by:
I cannot find a template for the officially release version as it is not available under the templates.
I added the following :
support for contact open/closed
in this way it will show up as open/closed in other smartapps like the web, so that you can easily see if open or closed.
support for door open/closed
responds to door open close commands to control so should be able to open/close in alexa…
still need to test this
I’m not seeing any code in that repository
Try it now
Can you also add scheduling to the st app similarly as it is standard feature in the keen home app. And it should be based on room sensor not thermostat. Thank you
You can schedule the vent via some automations.
