I’ve generally been installing things manually with the code copy, but I’m wondering if it’s possible to use update from repo for apps that don’t officially have that. Can I just put in the persons username and appname into the repo function the same way apps that come with that feature are set up so I can repo them as well?
Yes. If:
- The code is in a github repo; AND
- The github repo uses the ST required directory structure
