Hi all.
I currently have the aeon labs dimming module behind the retractive switch.
To dim the lights you press and hold the switch but sometimes it tries to turn the lights up, so you have to release the switch and press and hold it again to dim the other way
At work we use the 2 position retractive switches (push up or down and springs back to center) with specialised lighting control. Is there a dimming module that gives this option on smartthings?
