As the title says is there a difference between completely unplugging the power versus turning off the power from my Iris smart plug. The intent is to power cycle 15 minutes so the zigbee routes can update.
(A few of my lights are not responding so this is why I’m doing the 15 min power cycle).
Well, first of all, when you perform a zigbee force heal, you should power off for 30 minutes. And second of all, when you do this, all your lights might not respond right away since they are still forming their new connections to the hub. So, you should let your mesh settle for 24 hours before getting too worries about things not responding correctly.
Uhm…no, you can’t. Your IRIS smart plug connects to ST which connects to Alexa. Unplug your ST hub and your alexa cannot control your ST devices anymore.
I don’t think that is necessarily true. There are/were Zigbee Iris plugs. Some models of the Amazon Echo devices can directly control some Zigbee devices.
Which would have nothing to do with SmartThings since the plug is connected to Alexa and Smartthings is being powered down. So, the request is purely an Alexa question. You could use any wifi plug that connects to Alexa, you wouldn’t need to use an iris one.
But since there is no automation platform in alexa, you can’t automate the switch turning back on. You would have to do it manually. The only other option would be a custom wifi device like a Sonoff flashed with tasmota which allows rules to be written into the firmware.
Alexa routines include the ability to wait for a specific time. So a single Alexa routine could
Turn off the outlet
Wait 15 minutes (or whatever duration)
Turn on the outlet
I’m pretty sure the OP has this all sorted out. The only question posed was if shutting off the outlet was electrically the same as yanking the power cord out of the hub.
Which I don’t understand how they are doing from within Alexa. That is my point. How can you do that? Unless you schedule both the off and the on to occur at the same time every day/week/month, then there i no way to do this.
Updating the zigbee routes isn’t something you have to do on a routine basis. So, if that is what the OP is doing, they are actually destroying their zigbee mesh every time they do this. A force heal is only something that should be done in the rare case of adding a lot of new repeaters or moving a lot of devices around. Which means you’d want to do this on-demand which means the specific time schedule will not work.
What you would want in this case, is a virtual switch that you could turn on that would cause the outlet to turn off for 30 minutes and then back on 30 minutes after the virtual switch was switched. Which is not possible in Alexa, to my knowledge.
Then why would you say that they have a solution? Answering someone’s question and providing a solution are two very different things. I would suggest that unless you have an answer to the questions I asked, that you not say that the question doesn’t matter.
The OP had one very simple question: is turning off the outlet the same as unplugging the hub.
That was it. No indication any other help was needed. No more questions from OP is a clue to me that nothing else is needed.
My guess, given that the OP stated the switch could be controlled by Alexa, is that it’s a Zigbee outlet and OP has the correct Alexa device to directly control the outlet.
If that guess is correct then an Alexa routine, triggered by a voice command (no virtual switch needed), would be sufficient.
@HalD with all due respect you are the one completely over thinking this, and over stating the OP’s technical abilities. The OP got found out, he was trying to cover himself, so he mentioned Alexa, it was a troll comment and you bought it. He thinks turning off a smart plug may leave residual electricity running through it
