Yes it did go away for me. I also find you will get this if you get Intermittent Internet connection as well.
same hereā¦ have over 20 GE Zwave and zigbee switchesā¦
I had asked Duncan about these extraneous log messages and he had saidā¦
My hub was updated late on Friday and I havenāt seen any of these messages since then. @johnconstantelo, @RLDreams, @Navat604, @James_Watts yāall seeing the same thing?
You are right. No more LED status now. Wish they would do the same with the power reporting on ST/Centralite plugs so I donāt have to use custom DTH for local processing.
What is your issue with the power notifications in the logs?
If it is what I think you are referring to, I like seeing them.
It lets me know if the devices that are attached to it are in which state, on, off, doing something that takes more energy etc.
I have around 12 ST/Centralite plugs and because there is no way to define the frequency or wattage to display. Every 0.1 watt is an event. I could change the DTH to a non power plug or a custom DTH but I like to complain
Yes but having that granularity is nice for instant reporting and automations etc.
Hi @ritchierich,
Mine went away too, but not because of the firmware update. I think it may be related to other backend changes we donāt hear about.
Iām still on v16.9 of the hubās firmware due to a zigbee stack issue discovered with 16.11, so I was rolled back until ST can fix. Still waitingā¦
