Unknown device in zigbee path
Recently, about two days ago, I made a change of devices in my bathroom, replacing a Xiaomi plug with a relay module. Today I went to check the Zigbee connection path of my sensors and came across this “unknown device” in the middle of the path of the humidity sensor, which is practically next to the new module.
Everything remains working correctly. Its odd because the module itself is identified in his path and no devices appears as “unknown” in connected devices list of the hub.
Maybe a cache problem?
What device is showing when you click on the device in the path?
Can’t connect to the device…
Hi @marcos.scheffler
Thanks for sharing all the info.
Would you mind trying to control the device again, and then noting down the exact time (with timezone) when you do it? After that, please send us the hub logs so the team can take a closer look.
Provide the Hub logs through the my.smartthings.com:
  1. In the my.smartthings, enter “your hubs”
  2. Enter the corresponding Hub
  3. Click on “Dump Hub Logs”
  4. Change the reason for requesting hub logs if needed
  5. Click on “Dump Hub Logs”
  6. Confirm that the request is submitted
    Note: If you have more than one Hub, the name of the one involved in the issue.
Hi @Itati , thanks for your response. Device control, automations, … are all working as expected.
The “problem” is the “unknown” device in the connection path of “Sensor Temp/Hum Box”. If i look in the hub connected devices, all my devices are correctly identified and this “unknown device” is only shown in the connection path of this particular sensor.
If i try to click to open the device, it gives me the “Unable to connect to device” error
just dumped my hub logs.
Thanks for the update and for dumping the hub logs.
Could you also please share the exact timestamp (with timezone) of when you tried to open the device and saw the “Unable to connect to device” message? That will help the team line things up in the logs more easily.
Appreciate your help!
Don’t know the exact timestamp but i’ve open the device to see the connection path many times just before dumping the logs.
Timezone is UTC -3
