I’ve built a device handler and web service to control keypads on my Lutron lighting system. It works fine with the first device, but I get the error below when I added a second device. From what I’ve read here, ST won’t allow it. Is just a matter of the IP or the port? Could I set the second device to a different port and then use a switch to redirect the port or create a bunch of servers that listen on different ports? If that worked, would ST have a problem witht the response? I’ve read here about needing unique MAC addresses.
grails.validation.ValidationException: Validation Error(s) occurred during save():
- Field error in object ‘physicalgraph.device.Device’ on field ‘deviceNetworkId’: rejected value [0A0000BB:1F91]; codes [physicalgraph.device.Device.deviceNetworkId.unique.error.physicalgraph.device.Device.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.error.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.error.java.lang.String,physicalgraph.device.Device.deviceNetworkId.unique.error,device.deviceNetworkId.unique.error.physicalgraph.device.Device.deviceNetworkId,device.deviceNetworkId.unique.error.deviceNetworkId,device.deviceNetworkId.unique.error.java.lang.String,device.deviceNetworkId.unique.error,physicalgraph.device.Device.deviceNetworkId.unique.physicalgraph.device.Device.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.deviceNetworkId,physicalgraph.device.Device.deviceNetworkId.unique.java.lang.String,physicalgraph.device.Device.deviceNetworkId.unique,device.deviceNetworkId.unique.physicalgraph.device.Device.deviceNetworkId,device.deviceNetworkId.unique.deviceNetworkId,device.deviceNetworkId.unique.java.lang.String,device.deviceNetworkId.unique,unique.physicalgraph.device.Device.deviceNetworkId,unique.deviceNetworkId,unique.java.lang.String,unique]; arguments [deviceNetworkId,class physicalgraph.device.Device,0A0000BB:1F91]; default message [{0} must be unique]
