Unable to use motion and illuminance together in Smart App for Aeotec Trisensor
Hi,
I have a few aeotec trisensors at home which are mainly set up to operate the lights.
I’m confused as to why I can’t set motion and illuminance to run together as you’d be able to with a dumb passive infra red (PIR) sensor.
It seems like a pretty basic function but I get “beta function not supported for local execution”
I have found a couple of threads about this from years ago but can’t see a solution?
I’m using the IOS SmartThings App.
I can use Automations rather than the Lighting Smart App and it works but is a bit glitchy and I have to have several Automations to essentially do the same job.
Does anyone know of a way to use motion and illumination parameters in the Smart App?
Thank you!
Try this way: Add in IF same device twice, once for illumination, and once for motion. IF should look loke this
