Check the Default and Secondary CHANLIST value in the ztack_config.h file.
The TI example code uses Channel 11 so you will need to change the channel value to match your ST ZigBee channel or choose the value to scan all channels.
You can login into the SmartThings IDE the navigate to the HUB Tab to find out what Zigbee Channel your ST hub is using.
