I am no longer able to open the device control GUI by tapping on the device tile in the Smartthings app. I see a couple other posts from others with the same/similar problems, but no solutions.
Sure could use some help!
Same problem here. Some people mentioned downloading an old version of the app for now.
Do you have any ideas to point me how toward how/where to do this? Thank!
Use APK mirror or similar site to download the old APK.
Okay, thank you! Am I to assume that the app is broken, and Smartthings isn’t in any hurry to fix it?
App doesn’t work properly on all devices including mine, and Samsung doesn’t seem to be in any hurry to fix it. It probably works on there Samsung branded test devices.
Unfortunately, Home Assistant is looking more and more attractive. Thanks for the heads up!
Doesn’t work on samsung devices either… Same issue. App Downgrade is indeed only solution for now.
Do you know the recommended version to be downloaded? And I assume it’s possible to turn off updating on the app somehow?
Version 1.8.47.24.
Disable updates per/on the app in android store AND if you use a samsung, disable auto updates for the full samsung store.
