I am using lambda ARN function to trigger my devices using smartthings app. I able to discover my devices in smartthings app. The devices are listed in devices section .when i want trigger power on or off the command is not hitting lambda function is not hitting to the lambda function but when i change the dimmer value the command hits lambda function and generates log. this was not happening with power option. Capabilities that i am using is “c2c-dimmer”
You might get a ST staff in here, but I know they’re going to want you to open a support ticket through the dev portal if you haven’t yet.
In dev portal i’m not getting any sort help that’s the reason i posted here
