When trying to delete, move or change label / name of pre-existing devies I get
Oh No! Something Went Wrong!
Error
500: Internal Server Error
URI
/device/update
Reference Id
ae0867b0-b87b-46c3-87d1-7d650afb618d
Date
Fri Nov 11 10:16:28 UTC 2022
Adding new devices is ok.
NB:
Within ST app (IOS) trying to move or delete - “We are having network problems message”
Also when trying to add / update devices in ActionTiles V6 Connect app from IDE - graph.api.smartthings.com says Authorizing the selected devices failed; please try again later or contact support@smartthings.com
If I understand what you’re asking, you can rename, delete, or change rooms for devices in the new web interface by tapping on the device tile, then choosing the little gear icon to edit it. It’s slow because you have to do one tile at a time, but it works with the new architecture. I just tried it, and it’s working for me, FWIW.
If you’re trying to do things with the IDE, it’s in the process of being discontinued in the transition to the new platform, and is slowly being stripped of functionality as the transition proceeds.
