I have a room which has 3 separate light circuits if you will (each light has its own wall switch, they’re physically next to each other), but they all share the same permanent live.
This is what the live wiring looks like. Obviously each dimmer has a switched live running to the respective light.
A common live is fine. That is what you have to all your lights on a single floor anyway. It’s what happens with the other connections to the dimmer2s that count. Can you post a diagram showing the rest of the connections?
So I had a few days off and revisited - 2 out of 3 lights are now working, I must of wired them incorrectly!
The third light consists of 2 LED bulbs. When I turn the lighting circuit back on, the LEDs turn on but dimmer than usual. If I turn them on, the flicker for a second then go back down to a lower level. I can’t turn them off through SmartThings or the physical switch.
Is this a case for the bypass? The LEDs are only 2.5w each so 5w in total.
